18″ rims: 285/65 R18 – 5/10ths taller and 4/10ths wider than factory. Trimming may be necessary
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sonicbluerider, Oct 20, 2019.
  1. Oct 20, 2019 at 7:10 PM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    so I want to put 285/65/18 Cooper stt pro's on my 2019 STOCK !!!
    limited crewmax trd !!! do I really need to trim out my wheel wells to make them fit??? if so guess I'll have to stay with the 275's
  2. Oct 20, 2019 at 7:21 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. That’s barely bigger than stock. You won’t need to trim anything.
  3. Oct 20, 2019 at 7:29 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Aside from looking better, you wont even notice it
  4. Oct 20, 2019 at 7:31 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I had to trim the stock skid plate to avoid rubbing at full lock in reverse for 285 65 r18. Easy to do. Might have been the tire, or the spacer lift that came on the truck.
  5. Oct 21, 2019 at 3:56 AM
    Sonicbluerider
    Dennis
    2019 Tundra
