17" wheels won't balance
Discussion in 'Wheels & Tires' started by rodriguez2103, May 7, 2017.
  1. May 7, 2017 at 9:34 PM
    rodriguez2103
    rodriguez2103 [OP] New Member
    CHARLIE
    2007 Tundra Limited CM
    So I've recently purchased 17x8.5 Method Double Standard with 0 offset with Corsa All Terrain XL 285/70/17 tires. Tires are cheap about $120 a tire, truck is an 07 Limited CM leveled. Been to Discount Tire 3 times and they say they are balanced but at highway speeds between 55 and 60 the steering wheel shakes bad. I suspect it's the tires, can anyone chime in with suggestions?
  2. May 7, 2017 at 9:39 PM
    Road Force balanced?
    Sas and jberry813 like this.
  3. May 7, 2017 at 9:44 PM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Just put 35s on my 18s from discount and basically the same thing. I am going to try and a find a shop that has road force balancing.
  4. May 7, 2017 at 10:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Are those Method wheels hub centric, or do you have hub centric rings in them?
    ColoradoTJ likes this.
  5. May 8, 2017 at 4:22 AM
    rodriguez2103
    CHARLIE
    Yes twice
  6. May 8, 2017 at 4:22 AM
    rodriguez2103
    CHARLIE
    Lug centric
  7. May 8, 2017 at 4:28 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Switch the front pair to the rear and see if you can isolate. If the problem goes away, bring one tire to the front at a time and see which tire is the culprit.
    If you switch the front pair and the problem does not go away, you might have some other problem.
    If you can isolate to one particular tire, make discount work on it until its fixed.
    You said the tire is cheap... thats your first problem
    theraven, Sas, 831Tun and 7 others like this.
  8. May 8, 2017 at 4:50 AM
    rodriguez2103
    CHARLIE
    Yea everything I research guys say cheap tires are hard to to balance
    Heading in to DT in a few
    And yea they switched front to back and the vibration got better but still there. At that time they said one tire was way off on weight. I might just go with BFG KO2s they have a few in stock.
    32vsnake and NewImprovedRon like this.
  9. May 8, 2017 at 4:53 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm sure they know the tires won't balance and they are just trying to shove you out the door. Try the KO2s. I've been happy with them
    NewImprovedRon likes this.
  10. May 8, 2017 at 5:42 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    you usually (if not always) get what you pay for.
    haven't had a problem with my toyo's.
  11. May 8, 2017 at 5:58 AM
    rodriguez2103
    CHARLIE
    Starting to suspect that
    How will it balance on the machine but not on the truck (if they are balancing)
  12. May 8, 2017 at 5:59 AM
    rodriguez2103
    CHARLIE
    Yea at $120 a tire, plus I can't find any reviews on those Corsa tires anywhere. Was trying to stay budget friendly.
    Law323[QUOTED] likes this.
  13. May 8, 2017 at 6:02 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I hear you brother!
    Got toyo AT's but still wanted to save money, so I went the budget route on my lift (RC 3" spacer). Bad move! LOL
    After that, I realized it's best to do it right the first time. Why can't these things ever be cheap and good quality?? Dang it!
    TheBeast and ColoradoTJ like this.
  14. May 8, 2017 at 6:08 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Its probably not balancing on the machine, but really close so they just try to shove you out the door.
    Or, they don't know what they are doing.
    Or its not a true road force balancing and they are just telling you it is.
    Tire shops do not always hire the most qualified employees.
    Honestly, at this point I would get a full refund and go somewhere else.
    ColoradoTJ and Law323 like this.
  15. May 8, 2017 at 6:57 AM
    rodriguez2103
    CHARLIE
    To top it off my wife warned me about buying cheap
  16. May 8, 2017 at 7:25 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    oh that's bad!
    now she'll be giving you that "told you so" look......fricking hate that! LOL
  17. May 8, 2017 at 7:35 AM
    Newm
    Newm New Member
    KC
    ^ That wouldn't surprise me.
    Type in your zip in the link below to find some shops close to you that have Road Force Balancing capabilities
    http://www.hunter.com/gsp9700.
  18. May 8, 2017 at 7:43 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I put new tires and wheels on a Silverado that I had. When I got up to 70-75, the truck would vibrate and felt bouncy. It started in the front, then they switched it and did the same thing on the back. 70-75, would just bounce like crazy. I did BFG Ko2's, and must have had them put 4 new tires on them, still did it. They finally said the wheels I went with are not hub centric and they can order me new wheels. At that point I was done. I made them return it all, credit me and put my original wheels back on with new tires. Everything went back to normal.
    So I just assume it was a bad wheel, or because it wasn't the hub centric.
  19. May 8, 2017 at 8:25 AM
    rodriguez2103
    CHARLIE
    BFG KO2s didn't work
    They can't figure out why they won't balance.
    On the 17" wheel with the caliper grind down the heat the brakes produce was melting off the glue so the weights kept falling off. They did a dynamic balance and still no go. They put my factory 20" wheels and no vibrations what so ever.
    They refunded me my $$ so now I'm in the market for 18" wheels
    Bmxrider1331 and Voyagermike like this.
  20. May 8, 2017 at 8:30 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Go with hub-centric wheels. Lug-centric wheels are more likely to have vibration problems.
  21. May 8, 2017 at 8:53 AM
    rodriguez2103
    CHARLIE
    Will do, thanks
  22. May 8, 2017 at 9:13 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    From what I've read, the hub centric for a Tundra is 110 Bore. Maybe someone can confirm that?
  23. May 8, 2017 at 9:20 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yes 110mm
    Method and Icon have 110mm hub centric wheels in 17"
    I dont know why the OP would have problem with the weights on a 17" wheel. I run 17s and 35" KO2s with out issues.
    Law323 likes this.
  24. May 8, 2017 at 9:30 AM
    TheBeast The Beach
    good tires, good wheels, good shop: if you have Methods and BFG KO2, I would try a 4x4 shop specialized in suspension/alignment see if they can get it dialed in.
  25. May 8, 2017 at 10:43 AM
    rodriguez2103
    CHARLIE
    DT is telling me these Methods I have are lug centric, so try hub rings then? I don't get it either I know guys running this set up with no issues. FRUSTRATED!!!
  26. May 8, 2017 at 10:46 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    discount doesn't know what they are talking about.
    Method are hub centric. But some wheels are 116mm and some are 110mm. Tundra has a 110mm hub. 116mm wheel will work if you get an adapter.
  27. May 8, 2017 at 10:57 AM
    rodriguez2103
    CHARLIE
    Yea my wheels are 110mm hub
    Anyone know what size hub rings to order
  28. May 8, 2017 at 10:59 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    First you need to figure out the hub bore on the wheels you are trying to fit
    If not 110mm look for the correct adapter, ie 116mm to 110mm adapter
    Newm and 14burrito like this.
  29. May 8, 2017 at 11:08 AM
    rodriguez2103
    CHARLIE
    Got ya
  30. May 8, 2017 at 11:48 AM
    rodriguez2103
    CHARLIE
    These Methods I have are lug centric and been Road Force balanced 3 times with no luck. I'm done!
