17 tundra trans issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by 17ToyGuy, Sep 8, 2024.
  1. Sep 8, 2024 at 3:13 PM
    17ToyGuy
    17ToyGuy [OP] New Member
    Pete
    2017 tundra
    Had a speed sensor code replaced both input and output sensors on trans check engine light went out yet when I shift into drive it won’t go just revs like in neutral any ideas on what else could be the issue no check engine light is on.
  2. Sep 8, 2024 at 3:27 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You'll get some good responses here soon. There are some really smart folks in here.
  3. Sep 8, 2024 at 3:44 PM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    Did you notice any fluid leaks and did you check the fluid level?
  4. Sep 8, 2024 at 4:01 PM
    blenton
    blenton New Member
    My guess would be either transmission fluid is low, or poor electrical connections (such as disconnected plug or rodents chewing on wires) is causing the vehicle to not put he transmission in gear. Look up the transmission drain and fill procedure and associated fluid level check procedure here on the site.
    Retired...finally likes this.
