17 Tundra Engine noise on acceleration
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jcholm4145, Nov 13, 2024.
  1. Nov 13, 2024 at 3:32 AM
    Jcholm4145
    Jcholm4145 [OP] New Member
    https://m.youtube.com/shorts/ZmBpVwu3sdU?feature=share
    Hello all, new here but long time fan. I’ve been getting an electric humming noise on acceleration for quite some time now. Sounds the same at idle and during all speeds. If I feather the gas pedal it also makes the same noise. Replaced the fan clutch as I thought that could be the issue. I was also getting a slight tick from that area at the time that seems to have subsided. Power steering fluid is nice and clean. Truck has 105000. Could this be a grounding issue somewhere? The truck has a remote start installed from when I bought it from Toyota at 35,000. It will sometimes act up and cause my blinkers to flash nonstop until I turn the truck off and lock/unlock. I am very worried it could possibly be a drivetrain issue. I’m stumped. Also, belt has not been replaced since I owned it. Thank you!
  2. Nov 13, 2024 at 5:05 AM
    Jcholm4145
    Topped off the power steering fluid, no change. Plan on doing a flush and fill for the sake of needing it.
  3. Nov 13, 2024 at 6:00 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Sounds like power steering wine to me, noisy pump.
  4. Nov 13, 2024 at 6:09 AM
    Jcholm4145
    I’ll replace the fluid and see if it helps. Otherwise, look at replacing a pump?
  5. Nov 13, 2024 at 6:43 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Look at acquiring a mechanic's stethoscope. It reveals what whines exactly without second guess.
  6. Nov 13, 2024 at 6:43 AM
    Should be whining at idle too, maybe just not as noticeable. Have someone sit in the truck and turn the wheel left and right to see if the whining increases or changes while parked. Could be one of the other accessories that is belt driven also. Definitely engine speed related, so should be on the engine itself. Unless you have a supercharger you didn’t know about under the hood….
  7. Nov 13, 2024 at 8:09 AM
    Jcholm4145
    I wish I had one. Haha. And I bought a stethoscope. Idler seems ok. Should the tensioner have some extra noise because of how it works or should it be similar to a good idler? Otherwise, that may be the culprit. Warmed up, the noise isn’t as significant at idle. However, when I started it this morning at 48 degrees it was very noticeable. Still getting the same noise on acceleration at idle, while driving, and on deceleration.
  8. Nov 13, 2024 at 2:34 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    CHECK YOUR ALTERNATOR. I though mine was a power steering pump also, very noticeable when it was colder Flushed the system twice, no change in the noise. Turned out to be my alternator, the noise and area the noise comes from can be very deceiving
  9. Nov 13, 2024 at 3:28 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    If you are at a stop and it makes more noise turning the wheel, it is likely the PS pump. If it is with the accelerator, more likely the alternator.
  10. Nov 13, 2024 at 3:41 PM
    Jcholm4145
    Thanks for all the replies and the help. Changed the belt today, the tensioner hex bolt is stripped but it and the idler did not seem bad when I spun them. Also, seems like the alternator is going to be the issue. Anyone know how to get a replacement hex bolt for the tensioner? Also, getting quotes on the alternator job. The more youtube videos I watch, the more I am trying to convince myself I can handle it. haha
  11. Nov 13, 2024 at 3:42 PM
    Jcholm4145
    How much did the repair cost you? I expecting no less than 1000 in NC
  12. Nov 14, 2024 at 7:12 AM
    Jcholm4145
    Got a local import shop quote me 761 plus tax. Called Toyota and they want 2100! Crazy!
