17” Wheels on a 2012 Tundra
Discussion in 'Wheels & Tires' started by TalcTundra, Oct 20, 2024.
  1. Oct 20, 2024 at 7:57 PM
    TalcTundra
    TalcTundra [OP] New Member
    2012 Tundra Double Cab Regular Box SR5
    IMG_6132.jpg I have read a few posts on this topic but I need a little more info. I picked up a 2012 Tundra recently and it came stock with 18” wheels. I got almost new 285/70/17 bfg ko2s that I have on my other truck. I’d like to get some 17s for the tundra so I can use my tires. Planning on getting a levelling kit too.
    my understanding is that only some 17” wheels will fit these trucks because of the big brake calipers. I know Method 305s will fit but I’m not looking to spend big. My budget is under 1500 Canadian. Used wheels would be good but there’s not much on marketplace. I’m also a little concerned about buying wheels online that I’m not 100% will clear and then trying to return them if they don’t fit. Thanks guys
  2. Oct 20, 2024 at 8:58 PM
    blenton
    blenton New Member
    You are correct - only certain 17" wheels will clear the calipers, and the ones that do are still close enough to knock wheel weights off if they aren't positioned correctly. Wheel offset also plays in to it as well. Factory offset is +60mm; most aftermarket wheels are in the +10 to +27mm range with 0mm offset also being somewhat common. More negative offset pushes the wheel and tire further out from the edge of the fender but gives more clearance to the caliper. AFAIK, most reputable aftermarket wheels such as Method that are drilled in the correct lug pattern (5x150) have been checked for clearance if offered in a 17" wheel. The 5x150mm lug patter in not very common, so you are less likely to find a combo that doesn't fit as long as you stick to reputable brands. But I've not personally tried fitting 17's to my rig as I'm happy with the 18" wheel and tire offerings.
    SummitCO likes this.
  3. Oct 20, 2024 at 9:31 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    You can poke around this thread to see if there's a set of wheels that fit your truck, style and budget.
    https://www.tundras.com/threads/anyone-running-17-rims-on-your-2-5-gen.23617/
    It's 2.5 gen thread but same fitment for 2nd gen.
    You need 5x150 bolt pattern.
    As for offset, between +25mm to +35mm tends to be the sweet spot to bring the wheels out further, and about in line with the fenders.
    SummitCO and TalcTundra[OP] like this.
  4. Oct 21, 2024 at 8:01 AM
    TalcTundra
    thanks man, I’ve seen a few of the wheels on that thread and they’re around $300-400us per wheel but they do look great. I’ll keep reading I’m only on page 3 of 26 lol. Maybe if this truck were newer I’d be comfortable spending more on wheels but I’m gonna keep shopping around see if I can find something around $250canadian/wheel. I’d even run basic steel wheels if I can find them.
    eccracer104[QUOTED] likes this.
  5. Oct 21, 2024 at 8:37 AM
    TalcTundra
    IMG_0693.jpg I found some wheels within my budget, only concern is the higher offset, might rub a bit, more wear on suspension, fuel mileage, etc. Found a guy on a Facebook group who’s running them. Vision wheels is a reputable brand from what people are saying online as well.IMG_0697.jpg IMG_0694.jpg
  6. Jan 8, 2025 at 7:25 PM
    jayhawknavy02
    jayhawknavy02 New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    I don't know if this helps, but this is every 17" wheel (within reason) that I could find that looked remotely good for off-road use and semi-legit and above...lol.
    8.5" (+35) OFFSET WHEELS
    All Terrain Industries (ATI) AT-01 Hybrid Beadlock
    Price: $389
    Wheel Diameter (in): 17"
    Bolt Pattern: 5x150
    Wheel Width (in): 8.50"
    Offset (mm): +35 mm
    Backspacing (in): 5.88"
    Hub /Center Bore (mm): 110.15 mm
    Wheel Weight (lbs): ?? lbs
    Max Load (lbs): 3,637 lbs
    Note: Lifetime Warranty (structural)
    ATX Ledge AX188
    Price: $107
    Bolt Pattern: 5x150
    Offset (mm): +35 mm
    Hub /Center Bore (mm): 110.1 mm
    Wheel Weight (lbs): 25.77 lbs
    Max Load (lbs): 2,200 lbs
    Method Race Wheels 703
    Price: $319
    Bolt Pattern: 5x150
    Wheel Width (in): 8.5"
    Offset (mm): +35 mm
    Backspacing (in): 6.2"
    Hub Bore (mm): 110.5 mm
    Max Load (lbs): 2,650 lbs
    Wheel Weight (lbs): 27.91 lbs
    Note 1: Bead Grip for low pressure (Method)
    Note 2: Solid A356 Aluminum with T6 heat treatment (Method)
    Note 3: Reinforced inner lip from MRW race wheel for increased strength (Method)
    Note 4: Lifetime Warranty
    Method Race Wheels 705
    Price: $319
    Bolt Pattern: 5x150
    Offset (mm): +35 mm
    Wheel Weight (lbs): 25.55 lbs
    Max Load: 2,650 lbs
    Method Race Wheels 706
    Price: $319
    Bolt Pattern: 5x150
    Offset (mm): +35 mm
    Wheel Weight (lbs): 28.70 lbs
    Max Load: 2,650 lbs
    Raceline Race Wheels 958B Rogue
    Price: $269
    Bolt Pattern: 5x150
    Offset (mm): +35 mm
    Backspacing (in): 6.13"
    Wheel Weight (lbs): 28.82 lbs
    Max Load: 3,200 lbs
    Note 1: Solid A356 Aluminum (Raceline)
    Note 2: Lifetime Structural Warranty (Raceline)
    8.5" (+30) OFFSET WHEELS
    AS Forged Alloy Titan (Machined)
    Price: $499
    Bolt Pattern: 5x150
    Offset (mm): +30 mm
    Backspacing (in): 5.93"
    Max Load (lbs): 2756 lbs
    Note 1: T6061 aluminum construction
    Note 2: machined finish resistant to daily wear
    Note 3: Protected recessed valve stem design
    Note 4: Premium AutoSpec branded centre cap included
    ATX Sand Dune
    Price: $107
    Bolt Pattern: 5x150
    Offset (mm): +30 mm
    Backspacing (in): 5.46" / 5.93"
    Wheel Weight (lbs): 23.26 lbs
    Max Load (lbs): 2,500 lbs
    Method Race Wheels 316
    Price: $499
    Bolt Pattern: 5x150
    Offset (mm): +30 mm
    Backspacing (in): 5.44"
    Wheel Weight (lbs): 25.65 lbs
    Note 1: Solid A356 Aluminum with T6 heat treatment (Method)
    Note 2: Reinforced inner lip from MRW race wheel for increased strength (Method)
    Note 3: Lifetime Warranty
    8.5" (+25) OFFSET WHEELS
    Fuel Assault
    Price: $250
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Backspacing (in): 5.75"
    Hub /Center Bore (mm): 110.3 mm
    Wheel Weight (lbs): 41 lbs
    ICON Vehicle Dynamics Anza
    Price: $238
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Hub Bore (mm): 110.1 mm
    Wheel Weight (lbs): 30 lbs
    Max Load (lbs): 2750 lbs
    Note 1: Engineered to maximize caliper clearance and optimize wheel position for suspension travel and steering function (ICON)
    Note 2: Backspace dimensions and offset designed to reduce scrub radius (ICON)
    Note 3: Concave profile and deep stepped lip for trails (ICON)
    ICON Vehicle Dynamics Compression
    Price: $218
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Icon Vehicle Dynamics Nuevo
    Price: $238
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Note 3: Deep stepped lip for trails (ICON)
    ICON Vehicle Dynamics Recon SLX
    Price: $279
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Wheel Weight (lbs): 31 lbs
    Max Load (lbs): 3,200 lbs
    Note 3: Concave spoke design (ICON)
    ICON Vehicle Dynamics Rebound
    Price: $215
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Max Load (lbs): 3,100 lbs
    Icon Vehicle Dynamics Vector5
    Price: $198
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Max Load (lbs): 2,750 lbs
    Note 3: Featureless lip prevents debris entrapment for easier care and maintenance (ICON)
    Method Race Wheels 313
    (DISCONTINUED)
    Price: $351
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Backspacing (in): 5.80"
    Wheel Weight (lbs): 23.50 lbs
    Nomad Convoy 501
    Price: $246
    Bolt Pattern: 5x150
    Offset (mm): +25 mm
    Backspacing (in): 5.73"
    Hub Bore (mm): 110.3 mm
    Wheel Weight (lbs): 26.0 lbs
    Max Load: 2,500 lbs
    8.5" (+20) OFFSET WHEELS
    Western Rock ( WESROCK) Wheels BT-26
    Price: $191
    Bolt Pattern: 5x150
    Offset (mm): +20 mm
    Backspacing (in): 5.0"
    Wheel Weight (lbs): 28.20 lbs
    Max Load: 2,500 lbs
    8.5" (+18) OFFSET WHEELS
    ATX Sand Dune
    Price: $107
    Bolt Pattern: 5x150
    Offset (mm): +18 mm
    KMC BULLY OL (KM717)
    Price: $229
    Bolt Pattern: 5x150
    Offset (mm): +18 mm
    Wheel Weight (lbs): 24.47 lbs
    Note 1: Lifetime Structural Warranty
    Motegi MR149 MT6
    Price: $184
    Bolt Pattern: 5x150
    Offset (mm): +18mm
    Wheel Weight (lbs): 26.68 lbs
    Max Load: 2,500 lbs
    Note 1: Lifetime Warranty
    8.5" (+14) OFFSET WHEELS
    Fuel Covert
    Price: $353
    Bolt Pattern: 5x150
    Offset (mm): +14 mm
    Backspacing (in): 5.30"
    Hub /Center Bore (mm): 110.2 mm
    Wheel Weight (lbs): 32.6 lbs
    Max Load (lbs): 2500 lbs
    8.5" (+12) OFFSET WHEELS
    FK Ethos
    Price: $218
    Bolt Pattern: 5x150
    Offset (mm): +12 mm
    Backspacing (in): 5.25
    Wheel Weight (lbs): 25.00 lbs
    Max Load (lbs): 3,600 lbs
    9.0” (+25) OFFSET WHEELS
    FN Wheels
    Price: $299
    Bolt Pattern: 5x150
    Wheel Width (in): 9.00"
    Offset (mm): 25 mm
    Backspacing (in): 6.00"
    Hub Bore (mm): 110.2 mm
    Wheel Weight (lbs): 24 lbs
    Note 1: Knurled bead seat for enhanced low psi retention (FN Wheels)
    Note 2: Flow formed A356-T6 Aluminum alloy
    Note 3: 16.2mm diameter opening for extended thread “ET” lug nuts for short Toyota wheel studs (FN Wheels)
    Note 4: DOT, JWL-T, VIA, and SAE J-2530 approved (stricter than DOT, JWL-T, & other standards) (FN Wheels)
    Note 5: Reinforced inner / outer lips/flanges for increased strength and rigidity (FN Wheels)
    Note 6: High strength / high clearance barrel for brake clearance (FN Wheels)
