16in trd rims on 2006 double cab
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Jun 2, 2020.
  1. Jun 2, 2020 at 7:46 PM
    fighthedude
    fighthedude [OP] New Member
    Would 16in trd rims off a Tacoma fit on a 2006 tundra? I believe they are same lugs but curious about clearence around brakes... Also I see a bunch of guys talking about bigger or better brake upgrades.. 13wl?? Do this truck have the brakes I want or am I in need of the upgrade? Thanks fellas
  2. Jun 2, 2020 at 8:03 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    I did that, no issues.
  3. Jun 2, 2020 at 8:04 PM
    fighthedude
    Thank you for quick response.
  4. Jun 3, 2020 at 5:49 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You have the WLs on an 06.
  5. Jun 3, 2020 at 6:03 AM
    Professional Hand Model
    Hand Protectors
    Lots of nice Toy OEM Used 16” rims for sale online in the $100-200 range due to everyone going aftermarket and larger rims.
  6. Jun 3, 2020 at 6:50 AM
    speedtre
    speedtre New Member
    Inland Northwest
    What he said....the only big brake upgrade available to you that I'm aware of is the GX460 caliper upgrade....for that you will need 17s...and any 6 lug Toyota OEM 17s will work.
  7. Jun 3, 2020 at 7:29 AM
    Hand Protectors
    I’d like to hear from someone about the GX460 caliper upgrade that did only the calipers (minus booster/master cylinder). I went from WE to the WL and the braking is slightly improved, but overall not huge improvements.
    Going WL to GX460 I think requires doing the whole works. Calipers, booster, cylinder, etc.
    This is why I’d like to hear from others about it.
    I would definitely change all the flexible brake lines if they are original. Switch to braided SS with the coating over it.
