15 Tundra TRD PRO stock w/ Super Charger.. safe to use performace chip?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TrdProMan07, Nov 8, 2015.
  1. Nov 8, 2015 at 11:18 AM
    TrdProMan07
    TrdProMan07 [OP] New Member
    2015 Tundra TRD PRO doublecab Black
    Super Charger weather-tech Floor-Matt's
    -Wondering if safe to use the performance chips, an does it void my warranty?
    -What one's the best bang for the buck for the performance chips b/c tundra doesn't have many an the pretty PRICEY.
    - Is really worth that hassle to the get smaller pulley for my charger, does it really make that much difference?
    - Has anybody try the t mod- that you plug up into your gas petal an help to speed up the electrical throttle response?
  2. Nov 8, 2015 at 11:39 AM
    What performance chip? If you're S/C go Unichip and BullyDog tuner.
    You can adjust the throttle sensitivity on the tuner along with longer shift points.
  3. Nov 8, 2015 at 11:49 AM
    TrdProMan07
    does it void the warranty?
  4. Nov 8, 2015 at 11:53 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Not 100% on Toyota but GM will deny all warranty work if they see you have reprogrammed the ECU. So my bet would be yes it will void your warranty. @LOTSOFTOYS can verify this.
  5. Nov 8, 2015 at 1:02 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    If u got the pockets to pay for any damages then yeah, plug in a tuner and see if u can make the truck run better.
    MotoTundra likes this.
  6. Nov 11, 2015 at 3:02 PM
    Talstar
    Talstar New Member
    15 Tundra TRD PRO
    If you use a unichip you could remove it if the need arises and no one would have a clue.
