15 amp power outlet Fuse Blow out-2017 Tundra SR5
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 2017TundraNerd, Sep 27, 2024.
  1. Sep 27, 2024 at 2:04 PM
    2017TundraNerd
    2017TundraNerd [OP] New Member
    2017 Metallic Gray 4.8
    DRL Headlights, Dasaita Head Unit, Remote Power Starter
    Hello, new to the forum as a member. I was hoping someone out there has had a similar issue with their Tundra. Within the last month I installed DRL headlights from Headlight Revolution and at first they worked great and look beautiful on the truck but my 15 amp power outlet fuse under my dash keep blowing, just took the truck in to see if the shop could figure out the problem and they thought it was exposed connectors from the Dasaita head unit. That's clearly not the case as all the wires are now wrapped up and not pinched. Any idea as to why this could be happening or if you experienced this problem and fixed it would be a huge help to me.
  2. Sep 27, 2024 at 7:13 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Try posting this in the general 2.5 thread instead of the '2.5 Pro' thread as that will give you a lot more exposure...
    Also, if you search thread titles for fuse issue(s) w/headlights and do a separate search for fuse issue(s) w/taillights you should find some input. I remember seeing quite a few posts of folks having issues after switching over to aftermarket LED setups particularly w/the taillights, and if I remember right someone was able to identify the issue(s)
