15 Amp Brake fuse keeps random popping
Discussion in '2nd Gen Tundras (2007-2013)' started by KDog 1969, Sep 9, 2024.
  1. Sep 9, 2024 at 10:58 AM
    KDog 1969
    KDog 1969 [OP] New Member
    Kevin
    No rime or reason happens ever so often...really hot, cool, .....I can drive for weeks and not have any issues then go to put my truck in drive and the shifter is locked...replace fuse and we are good for weeks..then sometimes it blows three or four times ..then it doesn't then I'm good to go again for a week....have replaced the brake switch..still same issues. Thoughts?.
  2. Nov 17, 2024 at 5:21 PM
    TomsTundra
    TomsTundra New Member
    2011 DC 4.6L AT 4WD SR5
    Sounds as you have a intermittant short. Things like damaged or wet elctrical conectors or wire harness toucing the frame on occasion. Id check the wiring schematic for that circuit, probably see the fuse on the output side feeding a soleniod. Another possible culprit.
    KDog 1969[OP] likes this.
  3. Nov 18, 2024 at 9:03 PM
    lr172
    lr172 New Member
    07 DC
    Might look for debris in tow connector that is bridging rwo terminals in there. One is a grd
