140000, what maintenance to do?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zaoka, Jul 25, 2023.
  1. Jul 25, 2023 at 6:47 PM
    Zaoka
    Zaoka [OP] New Member
    Tundra 2020 SR extended cab
    Hi,
    Just got used 2020 SR tundra, extended one with RWD. It has 140000.
    What kind of maintenance is needed to keep it running nice? (Like new spark plugs, drive belt, brake flush, transmision oil…)
    Carfax does not show anything except oil changes and basics.
    Also how many miles these can usually make trouble free?
    2mchfun likes this.
  2. Jul 25, 2023 at 7:43 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I would do plugs, transmission fluid, coolant, and rear diff fluid for sure. I’d probably also do the brake fluid and power steering fluid while I was at it.
    Metro14536, 2mchfun and omgboost like this.
  3. Jul 25, 2023 at 7:45 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Oil change, Drain and fill differentials, transfer case, transmission, coolant, power steering, bleed brake fluid, change all filters, clean MAF, throttle body, change spark plugs, change wiper blades, change serpentine belt, idler pulley and tensioner, refill blinker fluid.
    Amount of trouble free miles depends on how the car is treated and maintained. Assume that nothing has been done to it maintenance wise.
    Nekodog, Metro14536 and 2mchfun like this.
  4. Jul 25, 2023 at 7:49 PM
    2mchfun
    Welcome from OKC! 140k? I'd be going through it pretty thoroughly. Basically depends on how you plan to use it and what your budget allows. Think things like wheel bearings, u joints, alternator, battery, maybe a starter, water pump, thermostat, filters, fluids, hoses, belt, fuel injectors, plugs, coil packs, wiper blades, ps pump, brakes, sensors, etc. I just like to replace components before failure and have total confidence in my vehicles. Others might have different opinions.
    omgboost, JLS in WA and Metro14536 like this.
