14 Tundra, 3/2 BDS kit, stock rims, max tire size?
Discussion in 'Wheels & Tires' started by Lesko, Aug 9, 2016.
  1. Aug 9, 2016 at 8:13 AM
    Lesko
    Lesko [OP] New Member
    2014 Tundra SR5 TRD Offroad
    BDS 3/2 leveling
    I am new to the site, and know this has been discussed, bit easier to post again rather than read 8000 threads. I have a 14 Tundra with a BDS 3/2 leveling kit. I want to run my stock rims (18x8.0 +60mm) and run larger tires. I am pretty sure i can fit 275/70s (33.2x10.8) without any rubbing at all on the upper control arm, but could i run 285/70s (33.9x11.5)? I have the worn down stock tires on now and there is not much space between tire and the upper control arm. I have heard the 2014 is tricky when running stock rims, so looking for advice from a fellow 14 owner with a leveling kit. Any info will be appreciated
  2. Aug 9, 2016 at 9:13 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
  3. Aug 9, 2016 at 9:16 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Short answer- 275/70's will work, 285 will probably work but it's iffy.
    Best thing you can do is go to a tire shop that you trust and do a test fit. Every tundra is different.
    If you're dead set on 285 and want to keep the stock rims, invest in some wheel spacers (1.25 is best)
    T-Rex266 likes this.
  4. Aug 9, 2016 at 9:23 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Lesko,
    I'm just learning more about our suspensions myself (I own a 2016 TRD packaged Crewmax) and mine hasn't been leveled yet, but seeing as how our Tundras came equipped with 275/65/18 tires and the 285/70's you want are just alittle taller and wider wouldn't adding spacers help clear the UCA? I don't know if that would present some minor rubbing issues on the flaps and all. Hang in there, I'm sure someone with more knowledge will help you out soon. EDIT ... I see Law was posting as I was typing. I told you someone would jump in here! Great forum with great members!!
    By the way, I started a Sky Silver picture thread ... Love to see you post something in there and welcome to the forum.
    Law323 likes this.
  5. Aug 9, 2016 at 9:44 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    your other thread wasnt enough? :bananadead:
    T-Rex266, Law323, Wilbur and 2 others like this.
  6. Aug 9, 2016 at 9:59 AM
    Lesko
    BDS 3/2 leveling
    Yea my bad, i thought i posted in the first gen tundra thread.
  7. Aug 11, 2016 at 7:18 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    You can do 295/70's I've seen a few guys do it no problem
