'13CM front coilovers / UCAs questions and help needed!
Discussion in '2nd Gen Tundras (2007-2013)' started by LiftMeUp, Apr 8, 2019.
  1. Apr 8, 2019 at 8:52 AM
    LiftMeUp
    LiftMeUp [OP] New Member
    I have a '13CM and looking to get 3" lift in front on a budget I plan on going with the Toytec / Eibach coilovers set at 3". I would like to run 285/65/20s (34.6") on stock wheels. The tire shop had a concern about clearing the stock UCAs with that size tire. But have been told that as long as I stay under 11.5" (width) I should be okay.
    I'm hoping not to have to really modify anything else for those tires to fit.
    So my questions are, is anyone running a 3" lift with those sized tires and able to clear the stock UCAs without a problem?
    Also, will I be able to get a good alignment with the stock UCAs?
    All is relatively new to me so any information would be greatly appreciated!
