139K Miles on 2012 4.6 tundra trans, should I drain n fill or leave it as is till it gives out
Discussion in '2nd Gen Tundras (2007-2013)' started by ERROD10, Oct 25, 2024.
  1. Oct 25, 2024 at 5:46 AM
    ERROD10
    ERROD10 [OP] New Member
    Needs come thoughts, the tundra I bought has never been serviced on the trans it has 139k miles, I keep hearing mixed reviews weather I should drain and fill, or just leave it as is, to keep the natural debris it already has in it.
    Long story short should I service the trans?
  2. Oct 25, 2024 at 6:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Drain and fill, no flush.
    Do the diffs and if 4wd, xfer case while you are at it. And lube your drive shafts zerks.
    snivilous likes this.
  3. Oct 25, 2024 at 7:18 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    ^^^^ x2 on what he said :thumbsup:
    It would take about 3-4 drain and fills to do a 'complete' trans fluid swap. So, if you start now and do another every 30k or so you will have exchanged most of your original fluid out by about 200k and shouldn't have the associated risks of doing a complete flush.
  4. Oct 26, 2024 at 7:18 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Bought our Tundra with a shade over 140k, and no record of trans service. Fluid was very dark from the first drain and fill, so I have no trouble believing it was original to the truck.
    I've completed 4 drain and fills between 145k and the current 190k. Every drain and fill has been performed in my garage with Toyota WS ATF, and the "back door" OBD paperclip leveling technique. I was very pleased to see the wonderful, red fluid which came out from the last service I did a couple weeks ago.
    The transmission is running smoothly and I plan to continue with the drain and fills once every year moving forward.
    Here's a great writeup added to the site earlier this year:
    https://www.tundras.com/threads/2nd-gen-transmission-drain-and-fill-diy-how-to.137487/
