13 Tundra Crewmax rear door speakers
Discussion in 'Audio & Video' started by JDfan49, Jun 16, 2025.
  1. Jun 16, 2025 at 8:14 PM
    JDfan49
    JDfan49 [OP] New Member
    My rear door speakers stopped working. Removed door panels, no wiring issues and nothing unplugged. Do they just stop working? Any help is appreciated.
  2. Jun 16, 2025 at 8:51 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    May seem obvious, but did you check your audio settings to make sure the 'fader' didn't accidentally get adjusted to the front only...
  3. Jun 17, 2025 at 4:40 AM
    JDfan49
    Yes I checked and it was not
  4. Jun 17, 2025 at 4:46 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Could be blown; are the foam surrounds intact? Have you checked fuses (some head units have a fuse in the back of the unit).
  5. Jun 17, 2025 at 9:07 AM
    JDfan49
    All the foams are in good shape. All fuses have been checked and all are in good shape
  6. Jun 17, 2025 at 10:57 AM
    shawn474
    MoCo, Maryland
    What year truck? Jbl or non jbl? Could be the amp has shit the bed
  7. Jun 17, 2025 at 11:40 AM
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    Both at the same time? Not likely the speakers then. Pull the hu out and check in the dash, or if you've done any work in the cab recently retrace your steps.
  8. Jun 17, 2025 at 8:09 PM
    JDfan49
    2013 Non-JBL....have not checked head unit yet. Will do that tomorrow. Have not done any work inside at all. All stock system
  9. Jun 20, 2025 at 9:27 PM
    Twinky
    07 double cab work horse
    If you want to check your speakers to see if they are still working, as in not blown, there are two easy ways to check them.
    Multimeter method. Just use the continuity setting and put one probe on the positive terminal of the speaker and the other on the negative terminal. If you hear the meter beep then the speaker is fine.
    Alternative method. Instead of a multimeter you can use a double A or tripple A battery. You'll need two short lengths of wire also. Connect each wire to a speaker terminal. Now with the other ends of the wires take one of them and hold it to the battery. Doesnt really matter if you choose the positive or negative for this. With the second wire just tap it to the other side of the battery 2 or 3 times kind of quickly. You should hear the speaker crackle or pop eacn time uou tap the the wire to the battery. If you hear the crackle/pop, then the speaker is still good and the problem is else where.
