13 tundra 5.7 4x4
Discussion in '2nd Gen Tundras (2007-2013)' started by Gregsneighbor, Oct 4, 2023.
  1. Oct 4, 2023 at 11:48 AM
    Gregsneighbor
    Gregsneighbor [OP] New Member
    2013 Tundra
    My neighbor has an 2013 5.7 tundra 4x4. He says that while in 4 wheel drive it made a loud popping sound. He says the it used to turn off road fairly smoothly but now acts like the front is not spinning the same speed while turning. ( basically it does not act the same as before) ok. I drove it and the 4x4 hi and lo acts perfect while driving straight. I cannot hear anything that is out of ordinary. But at lower speeds even in gravel, while turning. it feels like it is really fighting itself to even make a small turn. You have to give it gas and it will spin either one front tire or one back tire. Actually feels like it's in a low gear in front and high in back. Or like the brakes are engaged in front. No codes and other then the differential leaking out of the rear mount bracket I see nothing wrong. Front axles don't click on tight turn so cv should be good. Any suggestions on what to check would be appreciated. I know the fluid level needs checked/ filled. Thanks for help
  2. Oct 4, 2023 at 11:54 AM
    I’m not sure what you are calling the “rear mount bracket”. Or how the differential can leak from a bracket. This sounds like a transfer case or front diff problem, but would need further diagnosis.
  3. Oct 4, 2023 at 12:42 PM
    Cmende
    Cmende New Member
    California
    2013 Rock Warrior
    Dirt King boxed upper and lower control arms. Fox 2.5 shocks front and rear. R1 concepts drilled and slotted rotors. Baja Designs XL80 on the A-pillar and Baja Designs Squadron Pros in the fogs.
    I thought it was normal for it to be tough to turn while in 4wheel drive.
    PhotoNerd likes this.
  4. Oct 4, 2023 at 12:45 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome from TX new guy.
    Bad hubs maybe?
  5. Oct 4, 2023 at 3:35 PM
    treeandsome
    treeandsome New Member
    Is the transfer case locked?
