'13 Tree sporadic rear door open warning when closed
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by e30cabrio, Nov 22, 2024.
  1. Nov 22, 2024 at 11:22 AM
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    About a week ago, my dash started giving a warning I had never seen before accompanied by annoying dinging. My Kenwood has OBD2 integration and the vehicle reporting popped up rear door open warning. I stopped, checked, damn thing is closed. I opened & firmly closed it no warning, hit a bump, warning.
    I looked for the switch, there is no normal switch like on all 4 doors. Searched the google, the closest I have found was it's part of the handle.
    I just went out, no warnings going over sped bumps at 20+
    Anyone have this happen?
  2. Nov 25, 2024 at 5:05 PM
    e30cabrio
    New symptom, can't lock the truck with the fob, it thinks the door is open. I pulled the panel, everything looks fine. Although the door closes it clicks repeatedly when closed and then gives a long error beeeeeeeeeep
  3. Nov 28, 2024 at 3:56 AM
    e30cabrio
    Latch mech replaced, no change. Anyone able to help?
  4. Nov 30, 2024 at 8:54 AM
    e30cabrio
    Anybody?
  5. Dec 3, 2024 at 4:42 AM
    e30cabrio
    Not that anyone cares but yesterday I got a battery light, it was charging at 13.2. I checked the battery and it was at 11.7 when off, I gave it 10 amps until at 100% all night and so far no door warning.
    AZBoatHauler and KNABORES like this.
  6. Dec 5, 2024 at 11:17 AM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    I had issues with the latching mechanism on my 2015. It wasn't latching and the door would open on its own when driving, a few holy shit moments for sure. i tried manually moving the latch while the door was fully open and it seemed to hold ok but not when trying to latch onto the striker. I tried adjusting the striker, thinking it maybe got out of place, but nothing seemed to work. I small piece of rubber inside the latching mechanism fell out so maybe that was the issue. It was also a little packed with dirt.
    I purchased a replacement off ebay and the issue went away before I could swap out the part. Sounds like a different issue than yours but the latching mechanism was my issue.
    e30cabrio[OP] likes this.
  7. Dec 5, 2024 at 5:47 PM
    e30cabrio
    Mine was always latched, it seemed to be the latch, replacing it made no change. I don't get how everything else was fine but the damn latch needed full voltage.
    Weird.
  8. Dec 6, 2024 at 7:04 AM
    S. Equoia
    Ontario, Canada
    2015 Sequoia
    My issue seemed to show itself once it started to get cold last year but I'm not sure you have the same problem where you are.
  9. Dec 6, 2024 at 7:32 AM
    e30cabrio
    I'm in Phoenix. It hasn't gotten under 40 and I have not driven under 70.
    It had been happening over speedbumps yesterday it beeped once over a speedbump but immediately stopped.
    Freaking weird.
  10. Dec 13, 2024 at 7:20 PM
    e30cabrio
    I think I figured out the back door alarm problem.
    The fuse for the door system was slightly corroded. I replaced it and cleaned the contacts in the fuse box. On a sample of 1 20 minute trip the issue didn't happen
