12v wires for door panel
Discussion in '3rd Gen Tundras (2022+)' started by bongbong, Nov 9, 2022.
  1. Nov 9, 2022 at 3:25 PM
    bongbong
    bongbong [OP] New Member
    2023 Tundra Limited
    I was working on adding ambient light (similar to the Platium trim) for my Tundra but I cant seem to find a 12v inside the door (beside the courtesy light which turns off once door is shut).
    Anyone have a wire diagram or can point me to the right direction for all 4 door with 12v when car is on?
    Edit: I figured it out
    https://www.youtube.com/watch?v=7DLuiEOaQPI
    https://youtube.com/shorts/Ifws362GYY4
    Item used:
    Pins: https://www.amazon.com/Cermant-400Pcs-2-54mm-Connector-Terminal/dp/B095BQDH6F
    Aliexpress: 18 in 1 ambient light from Abilaen (will need double sided tape upon installation).
    Installtion note:
    • The front removal is only 1 step for armrest.
    • The rear removeal is 2 steps for armrest - it has extra bracket holding onto it. When putting it back, make sure to align it since there are tabs.
    • Cubby/storage hole light - if you're buying Aliexpress make sure to pick the package that has them. When you install it, you need to trim it shorter as it's too long. I used a scissor and rotate it then it grip it hard and it would snap off then I sand it down.
    • My installation was not perfect as I did break some tabs and somehow one of the mini speaker for the rear door panel tab broke off as I pull the panel open so pull it slowly. Luckily, I was still able to put it back on snug but required tape since I wasn't sure if it hold as a precaution.
    Delta1Seven likes this.
  2. Nov 9, 2022 at 5:33 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I have Limited and am researching a similar project. I purchased the two Platinum ambient lights for one door. One is the long horizontal blue light and the other lights up the little cubby hole in the center of the door. There is already a hole in my door panel for the cubby light. I hope to take panel off soon to see how the long led light fits under the upper armrest. Assuming the panel comes apart and I can add the light, I plan tap into the power supply that powers the blue window switch letters. The window switch dims with all the other blue lights through the control in the switch panel to the left of the steering wheel. Ill post pictures of lights when I get home.
    TX210Tundra and bongbong[OP] like this.
  3. Nov 9, 2022 at 5:52 PM
    bongbong
    2023 Tundra Limited
    I bought an aftermarket lights so I can have RGB, the power switch wire has 9v and the led I have needs 12v. Please show me the power supply switch you’re referring to which could be differ from what I’m seeing. Goodluck with your project as well!
  4. Nov 9, 2022 at 7:36 PM
    PERRY1060
    Perry
    Indiana
    Okay. I didn’t know the power to the power window switch was only 9v.
  5. Nov 9, 2022 at 7:52 PM
    Taco-Spike
    Two Trucks
    Get a volt meter and check your window control wires.
    I have my external side mirror drl’s controlled off this power.
    There is power there, just need to locate it and common ground. Should be a simple install
    this is my 3rd gen Tacoma but same applies for most all current vehicles
  6. Nov 9, 2022 at 8:04 PM
    bongbong
    2023 Tundra Limited
    That’s what I used but it seems like the 9v can’t power on my 12v led strip. Only one that has is the courtesy light but turn off as I shut the door. I likely missed a 12v wired so will open it back up again.
    Taco-Spike likes this.
  7. Nov 10, 2022 at 2:03 PM
    bongbong
    2023 Tundra Limited
    I found the 12v, it was the windows switch all along, however, I had to turn on the auto DRL mode to obtain the 12v. This is on the passenger side - pink for power and white is ground.
  8. Nov 10, 2022 at 2:12 PM
    bongbong
    2023 Tundra Limited
    Driver side - the very left bottom row cable (lighter purple) is power and the very right (pink) is ground
  9. Nov 12, 2022 at 3:04 PM
    RatPanda
    RatPanda New Member
    Ryan
    2022 Tundra 4x4 CrewMax 5.5
    Please let us know how this turns out. I’d like to do the same thing.
  10. Nov 12, 2022 at 3:26 PM
    PERRY1060
    Perry
    Indiana
    Here are pictures of the blue ambient door lights. Gonna be a bit before I can work on this because my wife’s parents are coming for an extended stay. 950749FF-247C-4309-9291-4596AD503FCA.jpg
    OnThaLake likes this.
  11. Nov 12, 2022 at 3:27 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  12. Nov 12, 2022 at 3:43 PM
    bongbong
    2023 Tundra Limited
    Do you have the part number and how much was all of this?
  13. Nov 13, 2022 at 9:27 PM
    PERRY1060
    Perry
    Indiana
    Yea have to find invoice. Ill post as soon as I find it.
  14. Nov 14, 2022 at 5:07 AM
    PERRY1060
    Perry
    Indiana
    1lowlife[QUOTED] likes this.
  15. Nov 14, 2022 at 1:42 PM
    PERRY1060
    Perry
    Indiana
    @bongbong here are part numbers and prices. Pretty sure part numbers are different for drivers and passengers doors. These are for passenger front door.
    810800c030 - $26.00
    810800c040 - $23.83
  16. Nov 14, 2022 at 5:13 PM
    bongbong
    2023 Tundra Limited
    Are these both the cubby hole part number or the long light under armrest?
  17. Nov 14, 2022 at 7:02 PM
    PERRY1060
    Perry
    Indiana
  18. Nov 16, 2022 at 7:14 AM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    I'm interested in the harness. If you don't mind including that info as well.
    Thanks
  19. Nov 16, 2022 at 8:46 PM
    PERRY1060
    Perry
    Indiana
    I haven’t pulled the door panel off yet to see if the harness is already there for these lights. I assume I will have to splice into the feed for the blue lights in power window switch
  20. Nov 16, 2022 at 8:58 PM
    bongbong
    2023 Tundra Limited
    I dont like spicing or any other ways of "biting", there are other methods - try male and female pins instead like I am doing. It's cold and windy as well, so I havnt work on mine either, waiting for weather to heat up a bit.
  21. Nov 16, 2022 at 8:59 PM
    bongbong
    2023 Tundra Limited
    @PERRY1060 see the pin?
  22. Nov 16, 2022 at 9:25 PM
    PERRY1060
    Perry
    Indiana
    Cool. Didn’t notice those when saw your photos the first time. So they fit along side factory pins in plug?
  23. Nov 16, 2022 at 9:34 PM
    bongbong
    2023 Tundra Limited
    Not perfectly snug but good fit which need electric tape to to secure it further as well as wrapping the exposed metal if you look where the tape are. I bought 200 pieces for like 10$ on Amazon.
  24. Nov 18, 2022 at 5:28 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I knew there had to be a light for the cubby but couldn't locate a part number. Does the harness in the picture come with the light?
    What kind of pins did you get? Are they made for piggybacking on the back of the plug or are you just using them like that? I want to add RGB ambient lighting to my truck but it's lower on the list of things to do. Also, my mom's nickname for me when I was little, is your user name.
  25. Nov 18, 2022 at 8:26 AM
    bongbong
    2023 Tundra Limited
    Kinda piggyback I would say - 18-24awg would fit in a bit loose but I would recocmmend that size.
    It means ballon in Vietnamese.
  26. Nov 19, 2022 at 8:41 PM
    PERRY1060
    Perry
    Indiana
    Not sure if question has been answered yet but the part numbers I posted above include two lights and harness. Still not sure if it will plug and play or if we have to tap into existing harness to power them.
  27. Nov 21, 2022 at 3:11 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  28. Nov 22, 2022 at 2:14 PM
    bongbong
    2023 Tundra Limited
    Rockgate and Siblue like this.
  29. Nov 22, 2022 at 3:16 PM
    RatPanda
    RatPanda New Member
    Ryan
    That is slick! Beautiful! I want to do the same thing. Great job. Hoping the setup is more or less the same for my SR5.
  30. Nov 22, 2022 at 3:22 PM
    bongbong
    2023 Tundra Limited
    This is what I got, not OEM, need double sided tape to install at those locations.
