12v Power Port question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr. Socom, Jun 6, 2021.
  1. Jun 6, 2021 at 5:47 PM
    Mr. Socom
    Mr. Socom [OP] New Member
    Los Angeles
    2021 Limited Tundra
    Hey all, recently got a dash cam and noticed it’s not automatically powering on like it would on my old 05 Tacoma. Idk anything about how these ports work. Is there a reasoning behind it not automatically turning on with the newer models?
    I connect it to the port underneath the radio.
    Sorry if this was already discussed, I couldn’t find it.
  2. Jun 6, 2021 at 7:04 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
  3. Jun 6, 2021 at 7:08 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I'm on a 2nd Gen so I don't have any factory USBs, but most cig lighters/ports are tied to ignition on like you're used too. It might be possible that's a data port for the stereo and not just your standard 5v usb charging port, in which case it might be tied to the stereo power? Hopefully someone else with a new Tundra can help you more.
  4. Jun 6, 2021 at 7:10 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    My dash cam connects to the cigarette port, so I don’t think this adapter would work :(
  5. Jun 6, 2021 at 7:11 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    Yeah I have no idea how they work. Just know it must be something with the new ones since my Tacoma didn’t have this problem.
  6. Jun 6, 2021 at 7:54 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    No, there should be nothing unique about how the power outlets on these trucks are wired. They are directly relayed/fused to the battery, and are live when the truck is in ACC or RUN.
    Saltyhero13 likes this.
  7. Jun 6, 2021 at 7:58 PM
    Mr. Socom
    Los Angeles
    2021 Limited Tundra
    Hmmm
    Might just be something wrong with my dash cam. I will get a new one and update you guys. Thanks fellas.
  8. Jun 7, 2021 at 11:20 AM
    gtoninn
    gtoninn New Member
    Andy
    2015 Tundra Platinum
    Sometimes there are settings to have it automatically turn on when power is applied. Otherwise I think you have to manually hit the power button.
    15whtrd likes this.
  9. Jun 7, 2021 at 11:42 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The power ports on my Tundra stay powered for a while after key-off if there is a load plugged in to one. I’m not sure if it’s a hour, or two, or???
  10. Jun 9, 2021 at 6:11 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I think only on trucks prior to 2014.
