12v power outlets always on
Discussion in '2.5 Gen Tundras (2014-2021)' started by Maadcaap, Jan 18, 2020.
  1. Jan 18, 2020 at 7:08 PM
    Maadcaap
    Maadcaap [OP] White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    In my 2016 4runner i made the 12v power outlets on constantly by jumping the fuses from the power seat fuse to the power outlet fuse... dont need to have ignition on to charge my devices, power my comms etc.
    forward to my 2019 crewmax.. the hazard fuse has 12v always.. i jumped it to the power outlet fuse(with an add a circuit) and the power outlets got power... but... the radio also turned on.. which is weird because the radio has its own fuse..
    has anyone been able to make their power outlets have constant power..?
  2. Jan 18, 2020 at 7:14 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    I used this method. Easy and clean.
    Ptundra and GWill like this.
  3. Jan 18, 2020 at 7:30 PM
    Maadcaap
    2019 Trd Pro
    275/70/18 KO2
    thanks.. looking to make the center console outlets on as well..
    EDDO[QUOTED] likes this.
  4. Feb 18, 2020 at 2:32 PM
    joezamora
    joezamora New Member
    Joe
    2019 TRD Pro
    Yes I want to get my hands on a schematic to see what the P/OUTLET relay is tied to.
  5. Mar 2, 2020 at 8:10 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Anything mocked up for the rear outlet?
  6. Mar 2, 2020 at 8:24 AM
    joezamora
    Joe
    2019 TRD Pro
    You’ll need to jump the P/OUTLET relay tips not the fuse.
  7. Mar 5, 2020 at 3:51 PM
    KFed
    KFed New Member
    East Tennessee
    2018 Tundra Crewmax TRD Sport
    Tinted windows, Black badge overlays, ProZ hard bed cover, 32" grille light, 30" lower bumper light,...
    Does this method affect anything else in the vehicle? Or just those 2 outlets...?
  8. Mar 5, 2020 at 4:10 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    The 12 volt outlet next to cigarette lighter stays hot for two hours on my 2nd gen
  9. Mar 5, 2020 at 4:15 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    No. Just those outlets. Hang on to the relay so you can go back to stock. Or if you change your mind.
  10. Mar 5, 2020 at 4:26 PM
    timsp8
    NY
    My 2010 did that too but they changed it sometime cause my 2018 doesn’t.
  11. Apr 3, 2020 at 1:09 PM
    brownmike
    brownmike New Member
    '17 CM 4x4
    Anyone know/notice there is a 15a fuse in the "Inverter" slot under the dash? I quickly google/forum searched and have seen nothing about a stock wired inverter...thinking maybe this would be a good port to tap for one? This is on my '17 SR5 CM.
    EDIT: It appears to have 12v with the ignition off/key out
  12. Apr 5, 2020 at 8:53 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    The factory gauge wire is tiny. Just unplug it and wire it with a fuse
  13. Apr 28, 2020 at 6:34 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    No fuse protection to the outlet with the jumper, right?
  14. Apr 29, 2020 at 3:20 AM
    Bammer
    Monroe, CT
    I reread your post, Still protected. :thumbsup:
    EDDO likes this.
  15. May 3, 2020 at 8:12 AM
    Bammer
    Monroe, CT
    Radio stays on when the jumper is installed, so I'm back to the relay being in full time. I guess 2019 is different than previous years?
  16. Apr 2, 2022 at 5:37 AM
    Punisher2.0
    Punisher2.0 New Member
    Nashville, TN
    2019 Barcelona Red Metallic Crewmax SR5
    @Bammer , ever have any luck figuring this out ? I’m the new owner of a 2019 CM looking to do the same thing .
  17. Apr 4, 2022 at 3:33 AM
    Bammer
    Monroe, CT
    Nothing yet, actually I forgot all about it after I failed at the first attempt. Time to get back on this again!
  18. Apr 4, 2022 at 5:44 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I ended up running a fused wire from the battery to the port in the center console. It was a pain, but I also replaced the 12v cigarette lighter plug with a dual usb.
  19. Apr 18, 2022 at 6:37 PM
    Punisher2.0
    Nashville, TN
    Ughhh I didn’t really wanna do that but looks like I might ... except for swapping the cig outlet , I like having the option for air compressor or usb or battery jumper
  20. Apr 19, 2022 at 3:53 AM
    Army_of_One
    OEM+
    I left the ones under the a/c controls, but they're not always powered.
