12v power in console
Discussion in '2nd Gen Tundras (2007-2013)' started by Hank, May 21, 2022.
  1. May 21, 2022 at 7:55 AM
    Hank
    Hank [OP] New Member
    2008 Tundra Limited
    Both of my power outlets in the center console have stopped working. The one inside the console lid, and the one outlet that faces the rear seats. The two outlets under the stereo are working. Is this two separate circuits? Anyone know exactly which fuse I need to check? Seems I’ve checked every obvious fuse so far.
  2. May 21, 2022 at 8:10 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    There’s a connector just in front of the console down under the shifter area for the wiring harness from the main dash to the console. You might check to see if something has damaged or disconnected it
