12v Hitch Wiring Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by styx, Mar 29, 2017.
  1. Mar 29, 2017 at 5:22 PM
    styx
    styx [OP] New Member
    Larry
    Knoxville, TN
    2017 SR5 DC TRD Offroad Magnetic Grey
    Raptor OEM Nerf Bars Leer Hard Tonnaeu Weathertech Vents Driver assist handle
    New to this site and Tundras. Have posted only a couple of times
    so far. I have a 2017 SR5 DC TRD Offroad MGM and am in the process
    of a few minor mods. The current mod is putting a "T" connector on
    the hitch receptacle in order to get 12v into the bed for bed
    lights, a 12v power outlet and USB charging ports. Bed has a hard
    tonneau. I was expecting the hitch receptacle to have 12v full
    time (last truck was a GMC and the line was always hot) but
    discovered 12v is available only when the ignition is in the "Run"
    position. Same as the cab ports. I could run a fused line direct
    from the battery to the hitch but I was wondering if anyone here
    has accomplished this using the factory line and moving it's
    source to a hot terminal. The wiring diagram I have only shows the
    backup light connection to the hitch port.
  2. Mar 29, 2017 at 5:29 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Hmmm, I haven't done this but I have a question for ya. Do you need the power to come from the trailer wiring or can you look into running new wires in loom with an in line fuse from the battery, neatly tucked and zip tied along the frame, and up into the bed?
    Gents would it be OK to run wires like that?
  3. Mar 29, 2017 at 5:52 PM
    styx
    Larry
    Knoxville, TN
    I have added a new line to a loom before when putting in a brake controller(on the GMC). I would have no problem doing this with this project but it is time consuming and of course with the uttering of profanity. Was hoping to make use of the factory line but without a wiring diagram or hints from a previous trail blazer I wouldn't want to tackle it. Most likely I will have to run a separate line and fuse. I hate to cut the factory line at the hitch.... hence the use of the "T" connector.
    This mod does not affect any trailer wiring. I pull a boat and have a utility trailer but both are standard wired. No electric brakes on either. Only need the 12v for the lights and outlets to be installed in the bed.
