12TechVolt Remote Start
Discussion in 'Tech12Volts' started by mpd13078, Nov 20, 2019.
  1. Nov 20, 2019 at 5:00 PM
    mpd13078
    mpd13078 [OP] New Member
    Alabama
    2017 Platinum Crewmax 4WD 5.7L
    Stock
    I installed the remote start system without the "mycar" option and it works great. Just use my factory fob. One thing though. Has anyone else experienced when the remote starter times out, the security alarm (horn) starts beeping until it's restarted? I contacted James and he said to connect the white and black wire if I planned on letting it run for more than 15 minutes.
    Thanks.
  2. Nov 20, 2019 at 5:06 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Oh shit. That's bound to happen. Time to rip both rigs apart.....sonofa....
  3. Nov 20, 2019 at 5:10 PM
    mpd13078
    Alabama
    Stock
    I'm more interested if anyone else is experiencing this and if they may have had the same situation and a solution.
  4. Nov 20, 2019 at 7:11 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I can’t help anyone at this point. But I have one of those from the group buy I am hoping to install this weekend. Supposed to be completely plug and play. Do you have Any recommendation on which vid to use as an installation tutorial?
  5. Nov 21, 2019 at 7:05 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I have my truck unit time out, but no horns or lights flashing. It just turned off. It happened to me while the truck was still locked and one after unlocking the doors, but not opening the doors. I contacted JRT and he told me that it will time out and this is normal.
  6. Nov 22, 2019 at 6:01 AM
    mpd13078
    Alabama
    Stock
    @KingsAustin,
    So when you let your truck remote start time out on its own, in its normal state without pressing any FOB buttons, it’ll shutoff as normal.
    If I understand you concisely, you have had the alarm go off at intermittent occasions as well. James said this was normal?
  7. Nov 22, 2019 at 7:17 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Mine just shuts off after 15 mins. Nothing extra or out of place.
  8. Nov 22, 2019 at 1:52 PM
    KingsAustin
    Morgan County, AL
    @mpd13078
    Just like @Zebruaj said, mine will shut off after about 15 minutes with no horn or lights. I reached out to JRT and he told me this was normal for it to time out and shut off. I am not having any other issues going on with my remote start. sorry if I confused you with my reply.
  9. Nov 23, 2019 at 10:09 AM
    tundradownsouth
    tundradownsouth New Member
    New Orleans
    19 tundra crewmax
    Hey for those that bought remote start w/ the car app. Which app did y’all download: the my car control or cl6 app?
  10. Nov 23, 2019 at 10:32 AM
    Snoman181
    Snoman181 New Member
    Reg
    Ottawa, Ontario
    2017 Toyota Tundra
    My install was a bit problematic, but through no fault of the installer (me) or the supplier (James). Turns out I had a faulty EVO-ONE box. James was incredibly helpful in helping sort this out. He even out me in direct contact with one of the tech experts at Fortin (the manufacturer). James sent out a new unit, I swapped with the defective unit, and everything worked like a charm. It was only afterwards that James asked me to send the old defective unit back to him.
    As far as the timeout and app go, I've run the truck until timeout after starting with both key fob start and app, and had no flashing lights, horn, or alarm issues.
    I downloaded the CL6 app, and after a brief setup issue (my error), the unit works just as advertised.
    My only question now is that the EVO-ONE with MyCar app has an option for an optional AUX accessory. I love the idea, but haven't figured out what else I would like to control remotely. Any ideas or suggestions?
  11. Mar 21, 2021 at 11:14 AM
    BlazingBluePlatinumFatMan
    BlazingBluePlatinumFatMan New Member
    2018 Blazing Blue Platinum
    Did you ever find out if there was anything to use with the optional aux accessory?
  12. May 16, 2024 at 9:45 AM
    Pcmc19057
    Pcmc19057 New Member
    Paul
    Silver 2015 crewmax sr5
    Hi MPD
    I know this is a old thread but I have the same problem with my remote start also.
    What did you finally do to stop the alarm from going off?
    I just stopped using mine years ago.
    Paul
  13. May 16, 2024 at 12:35 PM
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    Guys it is very simple . If you bought the remote start from us ,we sent you some instructions when we shipped it . In the instructions it tells you about a key sense wire that needs to be hooked up if you have a factory alarm . Once you hook up that wire. The alarm will no longer go off. It takes about 15 minutes to fix this issue as it is one connection. Email me if you no longer have those instructions and I will forward those instructions to you again . But only if you bought this from us . I have no idea if that is the problem if purchased elsewhere and do not want to tell you wrong . My email is tech12volt@gmail.com
    1lowlife likes this.
  14. May 16, 2024 at 2:19 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    yet another reason why James is one of the best; always willing to help and provides us great products at reasonable prices!
