12K Syn Rope on 9.5K Winch?
Discussion in 'Recovery & Gear' started by rmvcard0303, Aug 12, 2020.
  1. Aug 12, 2020 at 8:15 AM
    rmvcard0303
    rmvcard0303 [OP] New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    I’m new to using a winch. A
    friend passed down a Smittybilt XRC 9.5K with steel cables. I want to replace with synthetic rope. Just wondering if there are cons in using a 12k rated rope on a 9.5K winch. I do understand that the winch load must still be kept within the winch specs. Thanks for the input.
  2. Aug 12, 2020 at 8:22 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Two things to consider:
    Does it fit: what's the rope size and length? Check to see if the combo of rope diameter and length (like 3/8" x 100 feet) can fit on your drum.
    Is it enough weight: Your winch may only be rated to 9500 lbs but if you use a snatch block you can almost double the load.
    Based on the second item, I personally would not use the rope. I always look for a 2:1 winch max to line max.
