120v Water Pump Question
Discussion in 'Home Improvement' started by dumbassdave, May 19, 2020.
  1. May 19, 2020 at 11:10 AM
    dumbassdave
    dumbassdave [OP] Member
    Dave
    2016 Crewmax Limited
    I'm wanting to pump water from my pool to the roof of my shop. About 15' change in height and 200' of 1" pipe. Can anyone suggest what size of pump I should get?
  2. May 19, 2020 at 11:43 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Not a very big one, 200’ of 1” pipe only holds about 6.75 gallons of water when full. Your gradient is 0.75 (slope=rise/run) which is small too. I’m no pump expert but you’re looking as a pretty small pump, depending on how quickly you need it from point A to point B.
  3. May 19, 2020 at 11:55 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Maybe the resident h2o expert can chime in.
    @Rex Kramer
    dumbassdave[OP] likes this.
  4. May 19, 2020 at 11:59 AM
    dumbassdave
    Dave
    1/10 HP. 1/2 HP? Just wondering about how much jam I'll need to have this work and not be burning out pumps. It would only run for 2 min every 30.
  5. May 19, 2020 at 12:03 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Using larger than 1" pipe I would extend the pools discharge line to where I need the water to go, and then use the 'backwash to drain' feature built into the existing pool filtration pump to move the water. The less restriction, the better.
  6. May 19, 2020 at 12:08 PM
    dumbassdave
    Dave
    Thanks for the fast response. I tried using a filtration pump, but it died. I have a simple above ground pool. So I'm not sure about a backwash to drain feature.
  7. May 19, 2020 at 12:10 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    OP, is this for a water slide?:rolleyes:
  8. May 19, 2020 at 12:14 PM
    dumbassdave
    Dave
    A tough guy slide...... Asphalt shingle slide, 4' drop into 4' of water. Will film and post if I man up and try it
  9. May 19, 2020 at 12:33 PM
    PowerMan81
    PowerMan81 New Member
    Nor Cal
    2019 Tundra DC SR5 4x4
    It’s not so much about hp as much as you need a pump that can overcome the head pressure. Centrifugal pumps are heavily influenced by head pressure as the head increases the pump will eventually stop pumping known as shutoff head.
    You will need a pump that can pump the head plus the additional head caused by the friction of the water flowing through the pipe. When looking at pumps they usually tell you flow rates at various heads. The slope doesn’t matter vertical elevation is vertical elevation. The rated flow rate usually advertised is the max flow at little to no head pressure it can be somewhat misleading.
    long story short. Find a pump that gives the desired flow rate for the head it has to overcome. If the flow is below the minimum necessary flow rate the pump can burn out because the water flowing through it cools the pump and carries away the heat.
    if you happen to have a positive displacement pump than that’s a different story.
  10. May 19, 2020 at 1:08 PM
    dumbassdave
    Dave
    Thanks for the input!!!!
