12 x 26 Metal Biulding
Discussion in 'Home Improvement' started by flyguysc, May 4, 2020.
  1. May 4, 2020 at 7:47 AM
    flyguysc
    flyguysc [OP] New Member
    Looking to finish the interior of my new 12 x 26 metal shed. I was thinking of using fur stripes to attach panels to walls and ceiling. Any thoughts would be a help thanks in advance.[​IMG]
  2. May 4, 2020 at 7:51 AM
    flyguysc
  3. May 4, 2020 at 8:00 AM
    Kung
    KG, VA
    Were it me, I'd make dang sure first that the building is rated to do that; I'd have to finish that and then find out overtime the structure is compromised because the weight was too much for it to handle.
    Were it me, *if* it's rated to do this, I might likely build a frame out of 1x2 in between each of the metal studs, securing those to the floor/ceiling/studs, and then secure panels to that. Otherwise, you'd essentially have to build a frame inside the metal building itself, which will take up space.
    Disclaimer: Done a ton of DIY stuff @ the house, and made sure I did it *to code* when I did, but where I live is a non-code-bearing jurisdiction.
    Slayer and Luckydog like this.
  4. May 5, 2020 at 4:50 AM
    Slayer
    Slayer Member
    Slayer
    what kind of panels are you considering.
    lightweight?
    Like @Kung said. heavy materials may compromise your building.
    if you do install some sort of paneling.. insulate it with ridged foam.
    or than tin box will become a condensation factory.
    Good Looking Shed!
    looks well built.
    ..Slayer
    Toyotoholic likes this.
