-12 offset wheels
Discussion in '3rd Gen Tundras (2022+)' started by iLDE, Dec 29, 2022.
  1. Dec 29, 2022 at 3:45 PM
    iLDE
    iLDE [OP] New Member
    iLDE
    2023 White Tundra TRD off road
    Hello,
    I’m about to order wheels for my tundra. And I was just wanting to see some pictures of anyone that has any Method -12 offset wheels on their tundra? I’m wanting to order the 605 NV and wanting to see how much they stick out. Thank you
  2. Dec 29, 2022 at 3:49 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    About a foot. Seriously though, if the specs are about the same as the previous gen then they will poke out a lot. 25 puts it about 1/4 or so past the fender. So imagine a negative offset.
    iLDE[QUOTED][OP] likes this.
  3. Dec 29, 2022 at 4:14 PM
    motojunkie
    motojunkie New Member
    South Florida
    2022 Tundra TRD OR 2023 Supra GR
    I wouldn’t, guy at my work has -18 with 35’s and a RC leveling kit. Pokes way out and rubs on everything. Basically the truck can’t do uturns anymore lol
    iLDE[OP] likes this.
  4. Dec 29, 2022 at 5:18 PM
    hairychestedfrog
    hairychestedfrog New Member
    Idaho
    22 Tundra SS Red Plt CM
    Like they said above, don't do it. Too much
  5. Dec 29, 2022 at 5:28 PM
    iLDE
    iLDE
    Thank you
    Ordered different wheels.
    hairychestedfrog likes this.
  6. Dec 29, 2022 at 5:32 PM
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    OEM offset is +60 or so and the wheel is about 1"+ inside the fender
    I have Method with +35 offset and is barely starts to stick out about 1/2"
    For every 30mm you will push that wheel 1" outside. -12 will push your wheel about 2 1/2" out from where it sits now
    You sure is not a typo ? you meant to say +12 ?
  7. Dec 29, 2022 at 5:36 PM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    The truck can’t do u-turns stock lol
    MTRock, Leo's first, 9OH1 and 4 others like this.
  8. Dec 29, 2022 at 5:38 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I love the look of wheels sticking way out.
    Just Kidding.
    Leo's first and iLDE[OP] like this.
  9. Dec 29, 2022 at 5:44 PM
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    I’m running -10 with 35’s on a 3” lift. Not quite -12 but close
    A01D362E-A107-410B-A620-C11B1D023781.jpg 902D04A5-4568-4E6E-B288-739F3709CB6B.jpg FB404321-22CB-486F-8A14-ABD300CE1074.jpg
  10. Dec 29, 2022 at 5:46 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    FACT! Biggest gripe is the turning radius on the 3rd gen, it sucks donkey huevos
  11. Dec 29, 2022 at 5:46 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    That looks good. Not obnoxious.
    9OH1, iLDE[OP] and iiawah808[QUOTED] like this.
  12. Dec 29, 2022 at 5:48 PM
    motojunkie
    South Florida
    ha… this is true
    Skidmarcx[QUOTED] and iLDE[OP] like this.
  13. Dec 29, 2022 at 5:49 PM
    iiawah808
    Oahu, HI
    I honestly didn't want that offset but wanted SCS Wheels. SCS just released an 18" Tundra wheel with +12 offset for our 6 Lugs.
    I actually don't mind the poke and in person it definitely isn't obnoxious. The SCS -10 and -38 Offsets were meant for the 4runner/FJ/Tacoma's.
    BTBAKER[QUOTED] and iLDE[OP] like this.
  14. Dec 29, 2022 at 5:53 PM
    iLDE
    iLDE
    yeah, they’re -12
  15. Dec 29, 2022 at 6:35 PM
    motojunkie
    South Florida
    Look at the Method 305. Pretty much the same wheel as that 605 your looking at but comes in 20x9 +18. Not a deep dish though to get the more friendly offset.
  16. Jan 28, 2023 at 7:55 PM
    DarthTRDPro
    DarthTRDPro New Member
    Nick
    PA
    2019 Tundra TRD Pro
    -Coachbuilder TRD Pro kit (3”) -Cooper STT Pro Tires -1.25” BORA wheel spacers -ICI Magnum running boards
    Are you rubbing at all with this offset? Looks sick by the way. Same look I'm going for.
  17. Jan 29, 2023 at 12:11 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    6.5 crewmax actually has a tighter turning radius than the f-150 crew 6.5 bed. On paper, at least.
    It's about 5 feet longer than my 4Runner, but it still out-turns my extended-wheelbase sprinter :D
  18. Feb 3, 2023 at 10:48 PM
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Fox 3.0 Camburg UCA's and Trailing Arms KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV K&N Cold Air Intake and charge pipes Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs and Focal Components 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
    I have -12 offset
  19. Feb 15, 2023 at 8:34 PM
    DarthTRDPro
    Nick
    PA
    2019 Tundra TRD Pro
    Any rub at all? Do you have any other pics to show the poke?
  20. Feb 15, 2023 at 8:53 PM
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Ryuu, iiawah808, Yaboy and 1 other person like this.
  21. Feb 15, 2023 at 9:00 PM
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    37’s -12 and no rub just took off metal bumps in the front.
  22. Jun 20, 2023 at 9:35 AM
    Dandanthetundraman
    Dandanthetundraman New Member
    2023 Toyota Tundra Hybrid 1794 4wd
    None
    I have had a 2000, 2006, 2012 and now a 2023 Tundra. The worst ever was the 2006 model. It was so bad at turning I sold it a year after owning it. I think the electronic steering helps immensely even though the actual radius is still fairly large.
