110V plug behind mid-console. Is there any way to keep always on?
Discussion in '3rd Gen Tundras (2022+)' started by Silver '23, Jun 27, 2023.
  1. Jun 27, 2023 at 7:47 AM
    Silver '23
    Silver '23 [OP] New Member
    2023 Tundra Limited 5.5' Crewmax.
    N-Fab Nerf Step RS Running Boards. BAKFlip MX4 Tonneau Cover. Husky Weatherbeater Floor Liners.
    The minor issue I have is this plug behind the mid-console is energized by a button in the dash, by your left knee. My wife and I have owned a dozen cars and trucks with 110v plugs over the years and this is the first that I need to do an extra step to get power. My problem is I leave my phone charger hooked up to this plug, so I get in the truck, plug my phone into the cord, and begin driving. When I get to my destination and look down, that's when I see my 14% phone is now at 12%, instead of 50%, and I remember that this plug needs a quirky extra step...
    Does anyone know if there's a way or a setting to toggle to keep this plug on at all times when the truck is on? Thanks in advance.
  2. Jun 27, 2023 at 7:52 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    The 110v outlet does not have power when driving. The link above will bypass this useless feature and will power the outlet while driving but you still have to push that button on the dash. I dont think I've seen an alternate method for the dash button just yet. Most of us are just happy we can now power stuff on the go and we live with pressing the dash button.
    ryanwgregg likes this.
  3. Jun 27, 2023 at 8:06 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    The outlet does indeed have power while driving. I used it a couple weeks ago on a trip to charge my son's tablet while he watched it. Now from what I've read at that site with the harness, factory, it reverts to 100w when you take it out of park. To me seems silly.
  4. Jun 27, 2023 at 8:07 AM
    eddiefromcali
    Eddie
    100% Stock
    My bad, thats what it does. I know i couldnt power a heated blanket one time and assumed it lost power...so it reverts to 100w, not 400?
  5. Jun 27, 2023 at 8:17 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    From my understanding is it's 400w parked and 100w moving. It seems that it should be the other way around. I may be dyslexic also.
  6. Jun 27, 2023 at 8:22 AM
    eddiefromcali
    Eddie
    100% Stock
    I wonder if it does this to reduce electrical load and not impact highway mpg. If it can support 400w at idle, then the alternator should be able to support it at higher rpm!
  7. Jun 27, 2023 at 8:26 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    For others just in case. Ya, weird.
  8. Jun 27, 2023 at 8:31 AM
    mattvarnell
    mattvarnell New Member
    What am I missing? Don't understand why you want to charge phone via 110v plug. You are converting DC, into AC, to turn it back into DC to charge your phone. There are efficiency losses at each changeover that generate heat and wasted power. Just use a USB port in the console to charge your phone, as it is always on, closer, and has no conversion.
    GoTTi74, wedemmoez and Sixty9Four20 like this.
  9. Jun 27, 2023 at 8:32 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    They're not on unless the truck is. As for the power outlet. In a pinch, I've used mine because my plug in charger is faster than even the USB-C port.
  10. Jun 27, 2023 at 8:42 AM
    eddiefromcali
    Eddie
    100% Stock
  11. Jun 27, 2023 at 8:52 AM
    mattvarnell
    I know it's not on unless the truck is on, but his question is not about a plug being on 24/7. He says when he is driving he forgets to push the AC button. Depending on the phone, usb-c will be just as fast as an AC smart charger, but there are some older phones that do better with their smart charger.
  12. Jun 27, 2023 at 8:54 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I totally forgot to offer a solution to OP. You could possibly wire in a module that sends a momentary pulse to the button, whenever the truck is turned on/started. I can't remember the Directed electronic part number , but we used to use them for automation and bypassing Alpine HU parking brake steps. Or possibly the same thing that you can wire in to auto disable the auto stop/start feature.
  13. Jun 27, 2023 at 9:02 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I agree, just clarifying so that anyone that stumbles across this doesn't think so. My phone can charge at up to 68watts. My USB-C to C charger is only 30watts but it still higher than the console USB-C.
