11 years too late (pic heavy)
Discussion in 'New Member Introductions' started by Zebruaj, Dec 10, 2019.
  1. Dec 10, 2019 at 7:26 AM
    Zebruaj
    Zebruaj [OP] New Member
    MN
    08 CM SR5
    I finally bit the bullet and bought a truck earlier this summer. Went the long way around and changed cars from single to married to kids. Nothing too fancy. Just a bunch of fixes and mods for daily living.
    Previous vehicles:
    Picked up an 08 SR5 CM TRD off road package with 108k on the odometer. 1st day home in its stock used glory:
    Previous owner was a smoker, so found this to help clean out the odor:
    Noticed I could barely see my reverse indicators. Found the culprit:
    1st "mod" was to get rid of the plastic bed liner and inspect the bed. There were the usual rust spots in the front corners and behind each wheel arch. Went the DIY route with Herculiner. Now that I've done it, I would never do it again.
    Used the left over bed liner on the front skid plate as it was showing signs of surface rust.
    Next purposeful mod was a locking tailgate. I had these door lock actuators laying around from a previous project. Went the DIY and got it done.
    Maintenance was next. Plugs, belt, coolant, greased the driveline, pad slapped the rear pads. (not pictured PS fluid change, brake fluid flush, driveline fluids changed)
    Noticed oil was dripping from the cap's drain plug. Dealer mentioned a recent oil change. I went investigating and found that the plug was double gasketed. Changed the oil that day.
    Added some bed lighting in preparation of daylight's savings. Tapped the cargo light wire as identified by this forum. (Not pictured: added LED's in the cargo light and interior as well).
    Added "D" rings in the stock bed rail holes to help strapping in cargo.
    Found a grille listed locally and attempted to paint match it.
    Removed my dashcam from the 4Runner and put it in.
    Installed a Fortin Evo-1 remote start system
    Found some rear 4600 take offs to replace my worn out set
    Recently, found a set of 1794 20's and Tyger stararmor side steps. Put on 275/55/20 Falken Wildpeaks.
    As of Dec 2019
    All the maintenance and "needed" fixes are up to date. The rig is currently serving as the family van with homeowner duties.
    Now, time to research some fun mods and convince the wife they are needed!
  2. Dec 10, 2019 at 7:32 AM
    Nice.:thumbsup:
    MS22 and Zebruaj[OP] like this.
  3. Dec 10, 2019 at 7:32 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Wow that looks great you did a real nice job with the restoration and upgrades.
    GODZILLA and Zebruaj[OP] like this.
  4. Dec 10, 2019 at 7:33 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal
  5. Dec 10, 2019 at 7:37 AM
    18" TRD Off Road Wheels
    Very nice! Honestly, the only thing I would do differently is a smaller wheel, but if it's staying on pavement 20s will work well for you.
    Sunnier likes this.
  6. Dec 10, 2019 at 7:41 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Welcome from Bamaland. As you've already found ---- you won't have any trouble spending the kids shoe money or the upgraded New York steak money on your Tundra.
    Zebruaj[OP] and GODZILLA like this.
  7. Dec 10, 2019 at 7:45 AM
    Zebruaj
    MN
    08 CM SR5
    I just wanted an OEM Plus upgrade. The truck will only ever see some back service roads when we go camping and MN crap roads. I was holding out for the 2.5 gen TRD off road 18's but everyone up here wants an arm and a leg for them (when they come around). Found the 20's for almost nothing and couldn't pass them up.
    Boerseun and GODZILLA[QUOTED] like this.
  8. Dec 10, 2019 at 7:47 AM
    Solid plan, and honestly, they don't look like 20s with those tires. It's a sharp looking rig.
    Zebruaj[QUOTED][OP] likes this.
  9. Dec 10, 2019 at 7:49 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    :facepalm:
  10. Dec 10, 2019 at 7:50 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :smack:
    TXMiamiFan[QUOTED] likes this.
  11. Dec 10, 2019 at 7:53 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!!
    Zebruaj[OP] and Pinay like this.
  12. Dec 10, 2019 at 8:02 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Looking good, Nice Tundra!
    Had not thought about tapping the cargo lights, makes good sense.
    I also like the skid plate. Many have cut a hole in it for oil filter access; really easy and great to not remove any more.
    Other maintenance items to consider if not done:
    -Differential fluid change
    -Transmission Drain and fill
    Also, (if not already) Consider Interior LEDs for better lighting; Really brightens it up. There are some affordable ones out there. Also LED Tail & reverse lights are a nice touch. Signals are nice but are not as straightforward, and usually cost a bit more.
    Zebruaj[OP] likes this.
  13. Dec 10, 2019 at 8:08 AM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Welcome from southern NJ.
    Looks like somebody has been busy. Nice.
    T
  14. Dec 10, 2019 at 8:08 AM
    Zebruaj
    MN
    08 CM SR5
    Trooper2[QUOTED] and GODZILLA like this.
  15. Dec 10, 2019 at 8:16 AM
    Zebruaj
    MN
    08 CM SR5
    Haha. Yeah. Wife said I can never "not" modify my vehicles. But to my justification, the majority of this rig so far has been fixes or maintenance, aside from the recent purchases of the wheels/tires.
    Mcoop[QUOTED] likes this.
  16. Dec 10, 2019 at 8:26 AM
    Blue Thunder
    Washington
    Looking good...
    Asian vehicle antifreeze? WTF, is it 1979?
    ZappBrannigan and GODZILLA like this.
  17. Dec 10, 2019 at 8:31 AM
    Zebruaj
    MN
    08 CM SR5
    I know .. but it fits me since i'm an Asian driving this vehicle. Bwahaha.
    Good ol marketing. Big bold words for the 99%ers who don't know what to put into their cars.
  18. Dec 10, 2019 at 8:33 AM
    Looking good.
  19. Dec 10, 2019 at 8:39 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Welcome from Missouri.:hattip:
  20. Dec 10, 2019 at 1:22 PM
    Blue Thunder
    Washington
    Well, that's pure awesome sauce then. I would have paid money to watch the cashier's face on that one.
  21. Dec 10, 2019 at 1:45 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
  22. Dec 10, 2019 at 1:48 PM
    Zebruaj
    MN
    08 CM SR5
    Thanks. That was going to be my last resort. I tried the homemade remedy of baking soda and constant vacuuming, the Meguairs interior bomb, then found Ozium. A couple sprays a day over a week and the smells were all gone.
  23. Dec 10, 2019 at 1:50 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Excellent work sir!:hattip:
  24. Dec 10, 2019 at 1:51 PM
    MistrRoboto
    Virginia Beach, VA
    Nice! Its a pretty good last resort. Id crack a window to get the cord in, set it on the center console, and just run it for hours. Could also run it while the car is on and circulating air through the HVAC to really clean things out.
    Similar thing to what restoration companies use after fire damage, but smaller and cheaper.
  25. Dec 10, 2019 at 2:50 PM
    Welcome from TEXAS, schweeeet job
  26. Dec 10, 2019 at 2:57 PM
    TheBeast The Beach
    looks great !
  27. Dec 10, 2019 at 3:43 PM
    Zebruaj
    MN
    08 CM SR5
    Couldn't see anything out of the headlamps and still on the fence about Alpharex so put these in for now
    Blue Thunder likes this.
  28. Dec 10, 2019 at 3:44 PM
    Zebruaj
    MN
    08 CM SR5
    Also put in the base level Boss head unit with rear view cam. I drilled and imitated the OEM location.
    Trooper2 likes this.
  29. Dec 10, 2019 at 3:45 PM
    Zebruaj
    MN
    08 CM SR5
    Most recent interior mod was replacing the manual rearview mirror with a $5 Gentex mirror I pulled from the junkyard. 3 wires to tap and installed.
  30. Dec 10, 2019 at 4:57 PM
    Professional Hand Model
    Hand Protectors
    This is so rich on many levels!
    G10dra likes this.
