10K or 12K winch with front receiver
Discussion in 'Recovery & Gear' started by clarkritchie, Dec 1, 2021.
  1. Dec 1, 2021 at 10:23 AM
    clarkritchie
    clarkritchie [OP] New Member
    My CM weighed in at ~6,700 pounds the last time I checked.
    And my Draw Tite front receiver is rated at 10,000 pounds.
    Should I get a 10K winch in hopes that it (the winch) fails before my front receiver rips off? Originally I thought I'd get a 12K for the extra "room" not to mention the old buy once, cry once mantra.
    I don't expect to use this a whole bunch. Really it's just a backup in case I get my ass into a pickle when traveling alone.
    Thanks in advance.
  2. Dec 1, 2021 at 10:25 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    In your situation I'd go 10k since you're receiver is rated at 10k.
  3. Dec 1, 2021 at 11:28 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Do you have a picture of this, is this the one that kinda mounts under the bumper? Wanting to do the same thing, but worried a bunch about clearance issues. Actually been thinking of replacing the aluminum rebar and making a hitch there, so I can remove the front license plate, insert winch into receiver, pull away...
  4. Dec 1, 2021 at 11:37 AM
    clarkritchie
    Here you go. With no lift and 275/70-18 tires, the lowest point on the receiver is about 9-3/8" from the ground. So not great ground clearance but it works for me...
  5. Dec 25, 2021 at 6:28 AM
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    I run a 12k Apex. Works great. Same hitch as above.
  6. Dec 25, 2021 at 6:39 AM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Warn recommends multiplying GVWR x 1.5. At 6700 pounds that puts you just over 10k. However, as others have stated I would not go over the recommendation of your receiver.
  7. Dec 25, 2021 at 1:36 PM
    Kandgo
    Kandgo New Member
    R
    2006 4door 4x4
    Mine goes front, rear and into a receiver on my car hauler. The Badlands Apex’s are up at the top. I know several run them on their crawlers and abuse them!
  8. Dec 25, 2021 at 1:46 PM
    2mchfun
    You would be fine with an 8k winch and a block. Use a remote to control the winch and drive the truck simultaneously to get out of a bad spot. If alone you really shouldn't be taking very big chances to begin with and an anchor might be hard to come by in many cases. Have a shovel and be ready to bury your spare as a last resort anchor. As for the hitch, it has an idiot factor in the rating, pretty sure you will be hard pressed to break it if you do things right.
    clarkritchie[OP] and crewmaxlmt like this.
  9. Dec 25, 2021 at 8:01 PM
    GreatBasinTundra
    Reno, NV
    2020 Tundra SR5 DC
    Might be “fine” with an 8k winch, as long as all things line up. Need to have enough run for a 2:1 set up, simply need assistance out of a bad spot and is not winching against actual resistance, etc. I don’t disagree with you that it can work. For the cost difference a 10k is slightly under the recommended straight line pull strength for OPs reported vehicle weight and would be, IMO, a better suited piece of equipment for a truck as big as the Tundra.
  10. Dec 25, 2021 at 8:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My tundra has a fixed 10k warn. My previous Tacoma had a removable 8k but it sleeved into 2 recievers that I built alongside both frame members. I always have at least 2, sometimes 3 snatch blocks, which allows not just multiplying the pull but also less you pull from multiple directions at the same time. (uphill & forward, for instance)
    Addressing another issue, I have always preferred to ‘go solo’. Be prepared, get stuck, spend the night ‘or2’, have extra food and a sleeping bag. You can learn a lot about your limitations and how to be self reliant. Old fashioned ideas, I know.
    Dsptundra and GreatBasinTundra like this.
  11. Dec 29, 2021 at 7:38 AM
    clarkritchie
    Thanks, all. My receiver is actually rated at 9,500, not 10,000. Regardless, I think I'm going with the Smittybuilt X2O 10K synthetic which has a wireless remote. IIRC it was $550 at 4WP for Black Friday so will probably aim to pick that up next time it goes on sale.
    badmotofing3r likes this.
  12. Dec 29, 2021 at 7:48 AM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    A few questions for you:
    1) Did you install the front hitch specifically for a winch mount? For some reason when I saw this picture, I immediately wanted one, but I'm not sure I have a particular use for it lol.
    2) Do your 275/70/18 tires rub on the front sway bar?
    3) How do you like those Duratracs?
    I realize this thread is about your winch options, so it is not my intention to derail it. PM is fine if you prefer.
  13. Dec 29, 2021 at 8:03 AM
    clarkritchie
    That plus I wanted the flexibility to occasionally uses a bike rack in front, as in the pic below. This technically works with no extension in the receiver, however the rack does not rotate up 90° due to interference with the license plate. So I am going to trim this extension down a few inches to bring it in a little.
    And I'm a fan of Duratracs. This is my second truck with them. I didn't want to swap wheels or tires for winter, and these seem to do well enough for me in the snow. :thumbsup:
  14. Dec 29, 2021 at 8:05 AM
    HamHands
    Awesome. No front license plates here in Florida :cool:
    Thanks for the info! Any rubbing on that sway bar?
  15. Dec 29, 2021 at 8:06 AM
    clarkritchie
    No rubbing.
    HamHands likes this.
  16. Dec 29, 2021 at 8:17 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    With the use of snatch blocks and multiple connection points, you can spread the forces and reduce the amp draw.
    gosolo and clarkritchie[OP] like this.
  17. Dec 29, 2021 at 10:42 AM
    Ericbike6
    Eric
    Austin, TX
    Is it just barely missing from going up 90 degrees? If so, you could loose the plate mounting bracket and mount the plate straight to the bumper cover.
