100K
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rjlman, Sep 22, 2022.
  1. Sep 22, 2022 at 11:01 AM
    Rjlman
    Rjlman [OP] New Member
    Ray
    2018 Tundra Limited Crewmax
    None - cleaned up all the badges
    Just breached the 100,000 miles threshold. What are the true considerations from a maintenance perspective. I know plugs are 120K. I know what the manual says, but what is the consensus amongst owners. Thanks.
  2. Sep 22, 2022 at 11:10 AM
    18" TRD Off Road Wheels
    When it comes to maintenance, there is no consensus. Can't even agree on when to change the oil. You're going to get a bunch of answers.
    I'll say this, the maintenance guide in the book is the minimum maintenance for a a truck having an easy life. If you tow, off road, or drive in dusty conditions you should do stuff more often than it says. Besides, you'll never hurt it doing maintenance a little more often/early.
  3. Sep 22, 2022 at 11:12 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    If nothing is failing, squeaking, worn, rattling, grinding and you've done all the necessary maintenance within the manual within the right time, then there's really nothing to do.
    If you've done nothing but oil changes, expect a decent list of things to inspect and posibily replace.
    snivilous likes this.
  4. Sep 22, 2022 at 11:14 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Coolant flush, transmission fluid, serp belt, tcase if you haven’t done any of those yet
    WILLINH, AZBoatHauler and 07DCLimited like this.
  5. Sep 22, 2022 at 11:19 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Unless you've done them in the last 30-50k, then all fluids (tcase, engine, trans, diffs, brakes, coolant, steering) and filters (intake and cabin) and spark plugs and grease all the zerks. Not much else to do.
  6. Sep 29, 2022 at 7:55 AM
    Rjlman
    Ray
    Thanks gentlemen. Have had more than oil changes accomplished...but not much.
  7. Sep 29, 2022 at 8:41 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    In general, i usually take whatever the manual says, divide the mileage by 2, and I never have issues with my cars.
    ColoradoTJ likes this.
  8. Oct 26, 2022 at 3:58 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    When you change the serpentine belt it's always a good idea IMO to replace the tensioner pulley at the same time. I know from experience ( and not the good kind).
  9. Oct 26, 2022 at 5:14 AM
    Good suggestion.:thumbsup:
    I also keep a new or used belt on hand for reserve too. The bearings in all the idler pulley’s can be swapped out pretty easily as well. A pack of 5-10 can be purchased online for pretty cheap.
    WILLINH and dondino[QUOTED] like this.
  10. Oct 27, 2022 at 5:11 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Didn't know that about the bearings. I'll have to take care of that at 300K........:thumbsup:
  11. Oct 27, 2022 at 7:23 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    118k last month after Wyoming trip. Before and after the trip what I(Toyota) changed are engine oil, transmission fluid, brake fluid, both front and rear diff fluid, rear shocks were shot and replaced. Toyota recommended power steering fluid and coolant flush. Maybe next time. Brake pads are 5mm so will need them new soon.
