10 years, 130k mi maintenance suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by surffshr, Jan 6, 2025.
  1. Jan 6, 2025 at 6:46 PM
    surffshr
    surffshr [OP] New Member
    2015 White CM Pro
    All right y'all. I've run my 2015 TRD Pro since new and it will be 10 years and probably 135k miles when the actual 10 year mark comes up in February. While I have done my regular maintenance such as oil, tires, and brakes, I've really not done anything else short of pouring gas in it. Truthfully, I thought I'd be in a new truck about 2 years ago at the 100k mark. Then I got ran in to while coming home from work and ended up repairing the rust around my brake light (thinking trade-in). I just never found something better that I wanted to make payments on.
    Now I'm wondering what I should be addressing i.e. plugs, timing chain, trans fluid, coolant, water pump...basically long-term preventative maintenance items that I can prioritize and complete. FWIW, the truck runs great with no known codes or other issues and I'm not really a fan of dealerships. TIA
  2. Jan 6, 2025 at 7:46 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    My truck is a 2013 with about 92000 miles, this is what I have done for preventave maintenance, new serpentine belt, new fluids for the front, rear, and transfer case, new spark plugs, new trans fluid, new coolant, I checked my brake fluid and it looks brand new so I have not done that yet, and of course check and remove any rust, ( I live in the rust belt) Other than that I think you are good to go.
    surffshr[OP] and AZBoatHauler like this.
  3. Jan 6, 2025 at 9:53 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Plugs, pcv, coolant, every other fluid, belt, maybe a can of seafoam, clean radiator and bend back fins that need it, lube your zerks, new battery and a partridge in a pear tree.
    smokint, surffshr[OP] and mfelton18 like this.
