10" Rigid Industries Fog Lights Won't Stay On
Discussion in '3rd Gen Tundras (2022+)' started by romanlegion, Nov 16, 2023.
  1. Nov 16, 2023 at 10:13 PM
    romanlegion
    romanlegion [OP] New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    I've had my Tundra SR5 TRD Off-Road since May 2021 and after a few months of owning the truck, I had my front and rear bumpers replaced and added several Rigid Industries LED lights, including a set of SR-Series Pro 10" Driving Lights that replaced my stock/OEM fog lights. I am running these lights using the OEM wiring and fog switches. This set of lights has an amp draw of 4.94. I am not sure if this is drawing too much power that the electrical system shuts it off after just around 15 to 20 seconds. Is there a work around to this or should I consider replacing them?
    https://www.rigidindustries.com/sr-series-pro-10-driving-black-910613.html
    Thanks in advance if you have any insight or solutions...
  2. Nov 16, 2023 at 10:53 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    romanlegion[OP] likes this.
  3. Nov 16, 2023 at 11:04 PM
    romanlegion
    Roman
    Katy, TX
  4. Nov 17, 2023 at 8:37 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Install a relay. Trigger the relay with the factory wiring and run your own fused feed directly to the battery
  5. Nov 17, 2023 at 8:43 PM
    romanlegion
    Roman
    Katy, TX
    Thanks. Sounds good, but I am "electrical illiterate." LOL. I guess I'll have to go to a shop to have this wired up the proper way.
  6. Nov 17, 2023 at 9:47 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    If you have a test light with a bulb test the power at the light when it’s giving your problems . If you have power there use the light in series to see if your ground is a good ground . Only do this when it’s giving you problems . This will isolate if it’s a wiring problem or a light problem . 5 amps isn’t a whole lot but I do realize the triuck maybe sensitive to it
  7. Nov 18, 2023 at 1:34 PM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    Sounds like a bad product or a faulty wiring issue. I can run a light bar and ditch lights at the same time without any issues. Did you replace the stock wiring or did you splice it for the new lights?
  8. Nov 18, 2023 at 9:31 PM
    WITCHBANE
    WITCHBANE New Member
    Joseph
    2024 Tundra Platinum TRD Off Road
    I installed the Diode Dynamics Stealth bar recently and wired them inline with the Diode Dynamics Fog lights by using an H11 to DT LED splitter, like I had on my Tacoma. Now my fogs and stealth bar turn off after 20 seconds or so just as @romanlegion mentioned with his setup. The fog lights previously worked perfectly and stayed on without issue. I want to run the stealth light bar and fogs together by utilizing the fog switch, like I did on my Tacoma. ** Light Bar Amp - 9.8, Fog Lights - 3.8 (combined?). **
  9. Nov 19, 2023 at 6:01 AM
    romanlegion
    Roman
    Katy, TX
    Good to know that I am not the only one experiencing this. I think this has something to do with the amount of amp draw exceeding what the OEM wiring allows. I may have to wire the fogs to my Garmin PowerSwith like how the other lights are wired.
    WITCHBANE[QUOTED] and mmasse like this.
  10. Nov 19, 2023 at 7:39 AM
    mmasse
    Idaho
    I would say you have found the issue. These newer trucks have everything calculated by a computer nowadays right down to the air flow. Anything out of spec will cause issues.
    WITCHBANE likes this.
  11. Nov 19, 2023 at 7:52 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    Honestly using factory wiring is risky with higher draw lights. With my Tacoma, and all my buddies trucks I’ve done aux lighting on we have always used simple relays. It’s a way to keep factory switching with out taxing the factory wiring. You only use the factory wiring to trigger the relay, and the lights have there own feed from the battery. Here is a helpful video
    https://youtu.be/HmiqUZ0sRt4?
    si=7Q63IJ76452MgzXK
  12. Nov 19, 2023 at 10:06 AM
    WITCHBANE
    Joseph
    I think the Auxbeam switch panel may be the only safe option or an individual switch like @matth66 and others mentioned. Errr, lol. The Auxbeam just kinda seems not a Tundra thing in my Platinum like it was in my Tacoma TRD Pro, lol.
    I was also trying to locate the fuse for the fogs and see if I could go larger or piggieback with an adda fuse. Do you all think that is another option?
  13. Nov 19, 2023 at 10:13 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    The fuse is based on the draw and wire size, I wouldn’t just upsize the fuse. Add a fuse is an option. Always better to bring your own lead straight from the battery with an inline fuse imo.
    romanlegion[OP] and WITCHBANE like this.
  14. Nov 20, 2023 at 10:24 AM
    romanlegion
    Roman
    Katy, TX
    This is very helpful. Thanks.
