10/12 Inch underseat subs?
Discussion in '1st Gen Tundras (2000-2006)' started by Gabe_Rich68, May 12, 2020.
  1. May 12, 2020 at 2:05 PM
    Gabe_Rich68
    Gabe_Rich68 [OP] New Member
    Gabriel
    2006 Black Doublecab Limited
    Hey Y'all. I was looking to see if I could put either a 10 inch sub or 12 inch sub in my truck (06 Doublecab), underseat or otherwise hidden. The only pre - made enclosures (that I could find) are for 8 inch subs, and I would like to go bigger. Does anybody have any ideas as if a 10 or a 12 would fit? And how did you do it? Thanks
  2. May 12, 2020 at 2:15 PM
    Professional Hand Model
    Hand Protectors
  3. May 12, 2020 at 3:49 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Contact James at tech12volt. He probably has a solution for you
  4. May 12, 2020 at 5:27 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    A shallow 10 maaaaaaaaybe, 12 no way. Get a hold of a 10 and pop open the compartment to see if it's gonna work.
    FrenchToasty likes this.
  5. May 13, 2020 at 8:15 AM
    There used to be a JL audio stealth box that went under the center console. Held a 10" sub. Ate up most of the center console space inside. Under the seat, the cubic feets are gonna be limited which will limit which subs will sound good there. a shallow mount that needs less cubes and less depth may work, I would go the custom route. Build your own or have a shop build one for ya. Gotta be more space there than in these AC's.
    Darkness likes this.
  6. May 13, 2020 at 9:12 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Looks like a 10 to me. I think it should be pretty easy to build a box on this side, the other side is pretty small. If you're going to build it yourself pull the carpet back and see if any panels on the false floor can be unbolted, that would make it easier to build a box into the compartment.
  7. May 14, 2020 at 12:21 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    The JL Audio solution is still out there but it’s around $700 unless you can source a used one. Sucks that you lose the storage but I’ve heard one and it was pretty awesome..
  8. May 14, 2020 at 3:45 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    If I remember correctly I think a shallow 10 is the biggest you can do under the back seat without actually cutting out that compartment and building a box. I researched a bunch before doing mine and it seemed like two 8's was the optimal setup under the rear seat (also I was going for SQ over SPL). I just dynamatted the compartment to seal it and put the 8's in a 3/4" MDF top plate and screwed that onto the compartment.
  9. May 14, 2020 at 5:26 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    8s are so much easier to work with. It's a shame that the model specific units are so expensive for these trucks.
  10. May 15, 2020 at 4:55 PM
    abcinv
    Tommy
    South of ATL
    A used one in FLA for $400 and willing to ship (and several other Gen 1 Tundra items) -
    Darkness[QUOTED] likes this.
