10,000 mile oil change?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bammer, Jun 12, 2019.
  1. Jun 12, 2019 at 4:55 AM
    Bammer
    Bammer [OP] I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    My first Toyota truck, and the book says 10k oil change intervals. Do you all follow that schedule? I am a little hesitant, but will go with it if there is real live data saying anything sooner is a waste.
    Also, is there an easy way to convert the power outlets to power all the time??
    Thank you
  2. Jun 12, 2019 at 5:01 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    I've always gone by the 10K schedule. I'm over 100K now and zero issues.
  3. Jun 12, 2019 at 5:14 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    According to other threads on this website, people will go 10k with 5.7 Flex Fuel engines before changing their oil. They then sent in a sample of their oil to a company that will analyzes engine oil, and apparently it tested just fine. In fact, they say they could've run their oil longer if they wanted. Based on that I change my oil every 10k with Mobil 1. I've been doing it for years with no issues that I am aware of; I'm at 150,000 miles.
    The outlet thing. I added an always on USB port to my dash. I even added an always-on separate fuse box, and I'm in the process of adding an always-on USB and 12V outlet in the back of my truck in my camper shell.
    Instead of adding a separate fuse box I think it is possible to tap into the existing fuse box with an aftermarket fuse that allows you to add an additional accessory. I think it is called add-a-fuse, or something similar. It didn't go this route because I wanted to leave the stock fuse box alone.
    I hope someone who knows way more than I do about this stuff will add to my post.
    Fotnot and Bammer[OP] like this.
  4. Jun 12, 2019 at 5:15 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    I had been doing 5k intervals on my '16 for the last 50k miles and just went to the 10k. I'm about to hit 60k and checked the oil and it still looked good.
    Bammer[OP] likes this.
  5. Jun 12, 2019 at 5:30 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    10,000 on regular fuel new trucks to follow warranty? Flex fuel is 5000 on new vehicles for warranty?? After my two years since I have FFV I will continue on the 5K on my old TSS I use to go to 7 maybe 8k but that is just me.
  6. Jun 12, 2019 at 5:46 AM
    First.toyota
    First.toyota New Member
    David
    S.W. Washington
    2019 Tundra TRD Pro, Super white
    K&N Cold air intake, wireless charging, JDM Astar led front blinkers
    Who's Jack Burton?
  7. Jun 12, 2019 at 5:48 AM
    Black@Blue19
    Ken
    SE Texas
    Pork Chop Express!!!
  8. Jun 12, 2019 at 5:51 AM
    First.toyota
    David
    S.W. Washington
    I'm glad you caught the reference
  9. Jun 12, 2019 at 5:57 AM
    Black@Blue19
    Ken
    SE Texas
    The check is in the mail!!
  10. Jun 12, 2019 at 6:23 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    4.6 every 5000. Use synthetic oil. And have it changed, dont do it myself. Ran into an issue with a vehicle because they said I had no record of oil changes.
  11. Jun 12, 2019 at 7:12 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    5.7 here, went into dealership at 5k, no issues getting it done, they even scheduled me for 10k in August. Free 2 yr maintenance why not every 5k - at least for me.
  12. Jun 12, 2019 at 7:16 AM
    Black@Blue19
    Ken
    SE Texas
    5K to rotate tires 10k to oil change and rotate tires. On regular fuel
  13. Jun 12, 2019 at 7:17 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    10k Synthetic. Toyota "bulk" oil. No issues. Follow the book.
  14. Jun 12, 2019 at 7:19 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Oil changes under Toyota care are only every 10k. Check your receipt. Should have only been topping off fluids that needed it, tire rotation and inspection. If you want every 5k they will charge you for the oil change.
    Hammy68 and Bammer[OP] like this.
  15. Jun 12, 2019 at 7:24 AM
    csuviper
    Broomfield, CO
    I did every 5k in my 2012. I got the truck used at 25k miles and just wanted to make sure all was good. I traded it in at 70k miles. No issues. I did do the oil analysis on an oil change after ~6k miles and it came back all good. It stated that i could go many more miles and it will still be effective.
    Since i have Toyota care for 2 years on my new Tundra i am planning to stick with their regular intervals (oil changes every 10k).
    Bammer[OP] and JH5370 like this.
  16. Jun 12, 2019 at 7:31 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    nope, I got free.. LOL trust me, i did not get charged. Otherwise I wouldn't get back my truck right? That was the first 5k oil change too.
    2018TundraLimited and Bammer[OP] like this.
  17. Jun 12, 2019 at 9:24 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    flex fuel engines, which are predominant in the gulf coast states, have a toyota specified 5,000 mile oil change interval (2,500 if you actually run E85)...and are covered by Toyotacare
  18. Jun 12, 2019 at 9:26 AM
    RussellVaughan
    Houston
    one tip - if you want to save money and time, change the oil every 5k, but change the filter every 10k.
  19. Jun 12, 2019 at 9:28 AM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Mine is Flex Fuel so every 5k for me at my dealer.
  20. Jun 12, 2019 at 9:30 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Your dealer cut you some slack, and didn't argue about changing the oil at 5K.
    The bad news?...if they change it now, they aren't going to change it later. You'll only get, iirc, two oil changes in two years. They'll let you space them out however you want (might balk at interval less than a year), but I believe after two changes on them, they'll start charging you for them. I did my own changes; I don't let anybody mess with my drain plug. ;)
  21. Jun 12, 2019 at 9:51 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    If you use full synthetic oil you can easily go 10k or even 15k miles because synthetic don't really lose their viscosity. The biggest factor is keeping it clean during that time which is why I only use Toyota OEM or Wix filters.
  22. Jun 12, 2019 at 10:03 AM
    RussellVaughan
    Houston
    Not sure why there's confusion. The flex fuel engines require oil changes every 5,000...and they ARE covered by Toyotacare. I got free oil changes at 5, 10, 15, and 20k miles.
  23. Jun 12, 2019 at 10:06 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Agree on fact that oil doesn't break down , only additives break down or are lost. don't agree with save money and change oil every 5 and filter at 10 , should do just opposite . Change filter at 5 and oil at 10. Filters are cheap , and you can tell alot from visual on filter.
  24. Jun 12, 2019 at 10:12 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    0W-20 oil is only available as a synthetic.
    Bammer[OP] and JohnLakeman like this.
  25. Jun 12, 2019 at 10:50 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    not on a FFV. Mine were done every 5k. The difference in the FFV and the regular motor don't involve any lubricated parts in the motor so I am doing my own at 10k. I have no problem doing that with today's oil. Now if conv. I would still be doing every 3k. I don't run E85.
  26. Jun 12, 2019 at 11:06 AM
    JohnLakeman
    No confusion.
    @phabej owns a 5.7L Non-flex fuel. He apparently lives/bought the truck in a region that allows Non-flex fuel 5.7L engine. He got his first oil change at 5K, where owner manual recommends 10K for Non-flex fuel engines. Dealer doesn't really care how many miles are on if he's owned the truck one year or more. If it was less than one year, then the dealer cut him some slack on the 5K change.
    He said the dealer set up a future appointment for a 10K mile change (confirms Non-flex fuel). The dealer may have calculated a future time based on his driving history, but I suspect the appointment was for one year, or near end of 2 year Toyotacare. He should watch for 10K miles, or end of his Toyotacare...whichever comes first. I got a post card from the dealer letting me know it was about to expire.
  27. Jun 12, 2019 at 11:32 AM
    JohnLakeman
    One of the nicer features of GM cars is an oil life monitor that uses an algorithm GM Powertrain developed that uses miles driven, number of starts, and maybe some other factors to calculate percent of oil life remaining.
    My past GM cars (2006 Corvette, 2008 Malibu) with the oil monitor began to warn as the oil life approached the end. Typically this would be about 13K miles or more depending on your driving style. Recommended oil viscosity for both vehicles was 5W-30, which is available as a conventional motor oil. For that reason, I believe the 10K change interval is fine regardless of oil type. Toyota does not specifically recommend synthetic motor oil be used in the owner manual, but they do specify viscosity that is only available as a synthetic or blend.
    myt1 likes this.
  28. Jun 12, 2019 at 11:54 AM
    RussellVaughan
    Houston
    apologies, I did not realize he said non-flex fuel. you're correct then, he got extra oil changes for free.
  29. Jun 12, 2019 at 11:57 AM
    RussellVaughan
    Houston
    my 2008 Honda had this also. seemed to work...when my commute was heavy city driving I could get about 7,200 miles before oil life hit zero....but when my commute was all highway, I could get almost 12k. but then again I started burning oil at about 150,000 so....lol.
    JohnLakeman[QUOTED] likes this.
  30. Jun 12, 2019 at 12:04 PM
    JohnLakeman
    No apology needed. I just read between the lines. But, my point was it's doubtful he'll any get any more than two free oil changes with a Non-flex fuel 5.7L...unless the dealer is feeling generous.
