1" wheel spacer question
Discussion in 'Wheels & Tires' started by land cruiser kid, Feb 14, 2020.
  1. Feb 14, 2020 at 1:46 PM
    land cruiser kid
    land cruiser kid [OP] New Member
    2020 Black Tundra TRD PRO
    Hello,
    I've been looking online for 1" hub centric wheel spacers for my 2020 tundra pro. I've only seen a couple choices and one if them said I may have to grind my studs down a little for clearance. Have any of you experienced that and do you have any recommendations for where to get them? I'm putting on bushwacker OE style fender flares and would like the tires to be flush with the flares. Any help would be appreciated.
  2. Feb 14, 2020 at 1:51 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  3. Feb 14, 2020 at 2:27 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I have 1 inch Bora spacers. I didn't have to modify the studs at all since I'm running OEM TRD Off Road wheels that have knockouts in the back that allow them to clear. Just go with 1.25 Bora or Spidertrax and you'll be fine.
  4. Feb 14, 2020 at 2:37 PM
    land cruiser kid
    Thank you for the replies. I was hoping for 1" but I'll take your advice, hopefully the tires won't stick out to far.
  5. Feb 14, 2020 at 2:59 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Quarter inch is such a small difference. Doubt you will notice
    CallsignKodiak likes this.
  6. Feb 14, 2020 at 3:36 PM
    land cruiser kid
    Ok, thanks guys, I really appreciate it.
    jordan0317 likes this.
  7. Feb 14, 2020 at 11:07 PM
    land cruiser kid
    the lug pattern for a 2020 is still 5 x 1.50 correct?
  8. Feb 14, 2020 at 11:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    5 on 150
  9. Feb 14, 2020 at 11:22 PM
    land cruiser kid
  10. Feb 16, 2020 at 10:28 AM
    land cruiser kid
    I took off my wheel, measured the lug length, I don't see how a 1" spacer wouldn't work, since there's not quite an inch sticking out past the rotor. The backside of the wheel has indentations also.20200216_125628.jpg 20200216_125649.jpg
    kparrow, Boerseun and jordan0317 like this.
  11. Feb 16, 2020 at 11:48 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You'll be totally fine with the 1" spacers then. Same setup that I have. I think the rear studs are a little longer than the front. Here is what mine looked like.
    Front:
    Rear:
    Bob_Wiley and Voyagermike like this.
  12. Feb 16, 2020 at 2:05 PM
    land cruiser kid
    Sounds good to me, thanks for the pictures!
  13. Feb 16, 2020 at 2:11 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Here's an idea of what 2" Boras with 12.5" wide tires will look like. They're on the stock TRD OR wheels (+60mm offset) making them sit at roughly +9mm offset.
    Obviously no grinding with a 2" spacer, but figured I'd drop a pic so you may have some idea of what you'll be looking at. Was hard finding pictures to help me decide on a spacer size....eventually just pulled the trigger on 2" and I'm super pleased.
    Juankapr82 likes this.
  14. Feb 16, 2020 at 2:21 PM
    tstieb
    tstieb New Member
    2014 CM TRD
    I have 1in Bora spacers. I recently replaced my rear shocks and took some pics since this issue has come up before. I think they are fine.
  15. Feb 16, 2020 at 3:19 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Jake, what size tires are you running?
  16. Feb 16, 2020 at 3:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Right now I'm running the stock 275/65R18. I'm getting 295/70R18 put on tomorrow or early this week, though.
  17. Feb 16, 2020 at 4:20 PM
    oogabooga289
    oogabooga289 New Member
    1" spacers will clear the studs on the front hubs, but the rear hub studs are longer. If there are "pockets" on your wheel where the studs can protrude into, it's no problem. But if you want the studs to be sub flush, you need 1.25" on the rear.
    I got Bora 1" for the fronts and 1.25" for the rears. I wanted to make sure that my 35" tires didn't rub the body mounts. And based on my wheel offset adding 1.25" spacers up front may have caused rubbing.
  18. Feb 16, 2020 at 7:15 PM
    land cruiser kid
    I'm totally stock OEM. I'm installing OE style flares so I just wanted the stance to look right. Eventually I will go a size bigger tires on the OEM BBS wheels.
  19. Nov 1, 2020 at 1:44 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    1" Bora spacer on the rear of a '21 Pro. Plenty of room
  20. Sep 5, 2021 at 3:37 PM
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Confused, most guys are saying the rear studs are longer than 1". Just picked up set of the BBS Forged Pro wheels and like to know if I'd have issues running Bora 1". Apparently not...
    Where did you pick up the spacers?
    Thanks
  21. Sep 5, 2021 at 4:14 PM
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    I thought the same thing based off the info I found on this site. The spacers came off my previous Tundra.. I purchased them directly through Bora a few years ago.
  22. Sep 5, 2021 at 4:30 PM
    Vizsla
    Vizsla pretend2send
    That doesn’t look like a 1” spacer. Compare with the pics of others in this thread. Had to cut the rear studs for 1” spacer on mine.
    AggiePhil likes this.
  23. Sep 6, 2021 at 7:46 AM
    BCTRD
    BCTRD New Member
    B.C.
    Just to confirm are you running the BBS-Forged Pro wheels? I picked up a set that were new and taken off a Pro. If they don't grow on me will probably sell off for Methods although they are light compared to a set of Fuel Sledge (heavy) wheels I just sold.
  24. Sep 6, 2021 at 1:57 PM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    I have. A 21 pro with 1” Bora spacers. The rear studs stick through barely but the bbs forged wheels have a slot between lugs that the stud will sit into. No problems using those spacers.
  25. Sep 6, 2021 at 3:48 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Any pics you can share? Especially side profile to see how they align with the fenders.
  26. Sep 6, 2021 at 6:36 PM
    TrenThom86
    Trent
    NW Louisiana
    This is all I have for pics. I didn’t take any before I put wheels back on. As you can see, the wheels stick out barely past the fender.
  27. Sep 6, 2021 at 6:40 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Looks good. Are your tires 285/70’s?
  28. Sep 6, 2021 at 7:10 PM
    TrenThom86
    Trent
    NW Louisiana
    275/65. It’s what came on the truck. I’ll probably go with 285/70 when I wear these out.
    FISHN43[QUOTED] likes this.
  29. Sep 6, 2021 at 8:35 PM
    BCTRD
    BCTRD New Member
    B.C.
    Thanks for the pics and feedback. Truck looks great.
  30. Oct 18, 2021 at 8:03 PM
    Juankapr82
    Juankapr82 New Member
    Juan
    2020 Tundra TRD PRO ARMY GREEN
    Stock with original Fox suspension system
