1" spacers on the rear end
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigblue14, Jun 28, 2020.
  1. Jun 28, 2020 at 6:54 PM
    bigblue14
    bigblue14 [OP] New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Has anyone used 1" spacers on the rear end? My studs are sticking out ever so slightly. I'm putting them on to ease alignment issues. I'm thinking I'll grind out the wheels since that small modification doesn't appear structural.
  2. Jun 28, 2020 at 8:03 PM
    That is why the correct spacers for Tundras are 1.25" because of the stud length. Me personally I would not grind the wheels or the studs.
    OBXTundra and YardBird like this.
  3. Jun 28, 2020 at 8:10 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Don't you have recessed areas on the back of your wheels already. Most wheels, including the OEM wheels have little recessed areas which would allow for longer studs.
    Ignore the arrow on the photo. See recessed areas between bolt pattern.
    YardBird and TRDFerguson like this.
  4. Jun 28, 2020 at 8:14 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Because the rear axle of the Tundras are offset towards the passenger side, for whatever reason that nobody can explain, I have been thinking of using a 1" spacer on the passenger side and a 1.25" on the driver side to even it out a little closer. My OEM wheels will allow the 1" spacer to be used because the mounting surface has the recessed areas as in the photo above.
    YardBird likes this.
  5. Jun 28, 2020 at 8:59 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've got 1" spacers all around on mine. Works fine with OEM TRD Off Road wheels, and like @Boerseun said, should work with any wheel that has knockouts on the back.
  6. Jun 29, 2020 at 3:10 AM
    bigblue14
    Craig
    I have 1" spacers up front without issue. Agreed on the stud front. However for the wheels there are already pockets there which clear 90% of the studs already but would only need a little extra material removed to clear. It seems reasonable.
  7. Jun 29, 2020 at 3:10 AM
    bigblue14
    Craig
    I have pockets but they don't clear all of the stud. I would need to open them up slightly.
    Boerseun[QUOTED] likes this.
  8. Jun 29, 2020 at 5:27 AM
    Boerseun
    Ferdie
    Sarasota Florida
    If you have to do something, since it is minimal, I would cut the studs rather than bore/grind out the wheels. Studs are easy to replace if for whatever reason you want to do that later.
  9. Jun 29, 2020 at 5:53 AM
    bigblue14
    Craig
    That seems like the harder path since I would have to clean up threads.
  10. Jun 29, 2020 at 5:59 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Just curious, how do spacers "ease alignment issues" ?
  11. Jun 29, 2020 at 6:03 AM
    bigblue14
    Craig
    When I had it aligned the guy told me he had to remove the spacers to mount it into their machine because they weren't at the same width. I had planned to put on the rear spacers so I didn't push back much on the comment.
  12. Jul 5, 2020 at 4:19 PM
    bigblue14
    Craig
    Got around to finishing this over the weekend. All it took was a minimal amount of material removal. You can see in the one picture how little contact there really was. It was nice opportunity to clean the wheels inside and out.
    IMG_20200704_154238.jpg IMG_20200704_154200.jpg IMG_20200704_150930.jpg IMG_20200704_150923.jpg IMG_20200704_154238.jpg IMG_20200704_154200.jpg IMG_20200704_150930.jpg IMG_20200704_150923.jpg
  13. Jul 6, 2020 at 7:49 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Surprisingly minimal. Any issues with vibrations after install? Also nice Mac impact, didn't know you could run the Flexvolt batteries on those, pretty neat.
  14. Jul 6, 2020 at 8:39 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Did you remember to do your spare wheel also?
  15. Jul 6, 2020 at 9:26 AM
    bigblue14
    Craig
    Good reminder - thanks
  16. Jul 6, 2020 at 9:27 AM
    bigblue14
    Craig
    Right it didn't take much. I was on the highway this morning without issue or any noticed vibration.
    Mac tools is owned by Stanley Black and Decker as well. Mac uses more a chemically resistant plastic and overmold but same interface.
    300BLK[QUOTED] likes this.
