1 inch front T100 leveling kit??
Discussion in 'Suspension' started by se3388, Nov 4, 2016.
  1. Nov 4, 2016 at 9:47 PM
    se3388
    se3388 [OP] New Member
    2025 Tundra I Force Max Platinum Crew Cab, 1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    Is there a 1 inch front leveling kit for the 1997 T100 4x4? All I can find is 2.5 inch or higher. The truck is high enough I just would like it to sit a little more level which would be about 1 to 1.5 inches in the front.
    Steve...........
  2. Nov 4, 2016 at 10:20 PM
    TundraGuy80
    TundraGuy80 New Member
    WA
    2013 TRD Rock Warrior
    18x9 Fuel Gripper Wheels 33x12.5 Atturo Trail Blade MT Tires Bilstein 5100 Front & Rear Flowmaster Outlaw Exhaust Super 10 Muffler 2 in 2 out 20% Window Tint Color Match Door Handles
    Not 100% sure but from my research the front is approx 2" lower than the back, meaning a level kit comes as 2/0 or 3/1.
  3. Nov 5, 2016 at 4:44 PM
    se3388
    Thanks for the correction, I was just guessing. Probably couldn't tell much of a difference in a 1 inch lift on the front. Does the 2/0 inch kit consist of ball joint spacers and bolts?
    Steve.........
  4. Nov 5, 2016 at 5:24 PM
    TundraGuy80
    WA
    Usually just spacers c/w nuts & bolts from what I've seen. but there's a lot more options if you go with a 3/1 lift.
  5. Nov 5, 2016 at 7:14 PM
    se3388
    I think I'll just stick with leveling it for now, with anything more drastic I probably would induce a vibration or something.
    Steve........
  6. Jun 22, 2017 at 12:02 PM
    se3388
    I went ahead and installed a two inch ball joint lift in the front, my front was 1.75 inch lower than the rear. The lift gave me a full two inches in front and it looks a lot better (in my mind). I'll try to snap a pic when I park it on a level surface.
    Steve...........
  7. Jun 22, 2017 at 12:03 PM
    Can i see your T100???
  8. Jun 22, 2017 at 12:06 PM
    Have same year 323006 miles 4wd all stock would like a lil lift
  9. Jun 22, 2017 at 12:09 PM
    Have you seen toytec.com? They have a kit for T100
