1 inch block
Discussion in 'Suspension' started by Glockman19, Sep 26, 2019.
  1. Sep 26, 2019 at 1:20 PM
    Glockman19
    Glockman19 [OP] New Member
    Hello everyone,
    I have a quick question for you. I am looking to add a one inch block to the rear of my truck. And wanted to know if I can keep my stock rear shocks or do I need to change for a longer one.
    Thanks
  2. Sep 26, 2019 at 1:24 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    The stock shocks should be fine with a 1" block.
    I have 1.5" blocks and stock shocks; I drive around on rough graded construction sites every day and never had a problem.
  3. Sep 26, 2019 at 3:24 PM
    You are only decreasing shock travel by an inch so you will be fine. However, adjustable shackles would be a better option, and better ride.
  4. Oct 1, 2019 at 11:16 AM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I added 1''Pro Comp blocks with my stock shocks and rides just fine.
  5. Oct 1, 2019 at 12:26 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Like everyone else said, you’ll be fine. But I also suggest shackles instead of blocks. Check out Coachbuilder
    Tundyfundy likes this.
  6. Oct 2, 2019 at 2:14 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    What he said
