1.75 Rough Country spacer and 295/70/18 tires
Discussion in 'Suspension' started by chris8837, Nov 25, 2024.
  1. Nov 25, 2024 at 1:29 PM
    chris8837
    chris8837 [OP] New Member
    I just put this on and I took it to some mild dirt and have a slight pop noise when it’s bouncing up and down. Do you think I’m bottoming out and need bump stops or something else?
    2024 Tundra 1974
  2. Nov 25, 2024 at 2:08 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Mine never did that. Who put the spacers in? If it was you, did everything get tighten up. Remember that these don't shorten the springs but do extend the length of the shock a full bounce so your shock could be running out of length?
    Are you running the standard shocks or anything different like the TRD ones?
    Was there any air time included in your dirt adventure?
    There should be any clunking going on and these spacers are so mild that they shouldn't over extend anything.
  3. Nov 25, 2024 at 3:13 PM
    chris8837
    I had a shop put it in. I’m taking it in next week. It’s a weird noise for sure. When I hit a hard bump doesn’t do anything. It’s like when it a sharp quick hit. It’s an odd noise. I don’t think they twisted the top hat also. I think they just twisted the bottom and stuck it in there. Think that could be the problem? I do t tink they put it in a spring compressor and twisted the shock to line up
