0W-20 Engine oil Brand Suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14 Tundra, Jan 14, 2020.
  1. Jan 14, 2020 at 5:46 PM
    14 Tundra
    14 Tundra [OP] New Member
    2014 White Tundra
    Leveling lift kit
    Looking for suggestions for engine oil brand, other than Toyota
    Thanks
  2. Jan 14, 2020 at 5:48 PM
    I use Mobile1
    Ajkkane, jerzeedivr and 15Yota like this.
  3. Jan 14, 2020 at 5:58 PM
    Chonfelito
    Chonfelito New Member
    Utah
    2016 Tundra Crewmax Sunset Bronze Mica
    amsoil for me because it allows me to go 15-25k between changes
    619Tundra and SIMPLYTHETRUTH like this.
  4. Jan 14, 2020 at 6:20 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You can get some good deals on Shell Rotella gas truck synthetic oil these days. Big rebates can make it almost free. You'd be hard pressed to find a synthetic oil that isn't good to be honest. Don't overspend.
    Zebruaj and BTBAKER like this.
  5. Jan 14, 2020 at 6:22 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I used Castrol
  6. Jan 14, 2020 at 6:25 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I recommend Amsoil Signature. Run it until your truck starts to use a little oil. Not a specific mileage.
    Mobil1 is good too
    619Tundra likes this.
  7. Jan 14, 2020 at 6:29 PM
    fuzzamungus
    fuzzamungus New Member
    18 Tundra Limited
    Mobil 1
    Ajkkane likes this.
  8. Jan 14, 2020 at 6:42 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'm using Mobil 1. At 6,000 miles on the oil it is still gold color.
    Ajkkane likes this.
  9. Jan 14, 2020 at 6:43 PM
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    I use Pennzoil Ultra Platinum purchased from Walmart. I used Mobil 1 previously but switched to this oil after doing some research. This oil is supposed to keep pistons and rings cleaner, and the Tundra engine is known to have a problem with rings sticking, causing the engine to use oil. Oil 2.jpg
  10. Jan 14, 2020 at 6:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Totally unscientific, but castrol edge doesn’t feel as good as mobil 1 to me. I dont think the truck sounds the same and the consistency seems more watery.
    I like amsoil and mobil 1, but im trying out the rotella for a while after the amazing sale!
    Rica25 likes this.
  11. Jan 14, 2020 at 7:09 PM
    Mobil 1 here.
    Ajkkane and Rica25 like this.
  12. Jan 14, 2020 at 7:11 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Mobil 1 FTW
  13. Jan 14, 2020 at 7:15 PM
    Gatire
    Gatire New Member
    2014 Tundra
    I recently switched to M1 5w50. Engine is def quieter. So far so good
    Rica25 likes this.
  14. Jan 14, 2020 at 7:16 PM
    Mr Badwrench
    Mr Badwrench New Member
    If it has an API stamp, it is good. Synthetic SuperTech from Walmart is just fine. Buy whatever is on sale (with the API stamp), and you will be good.
  15. Jan 14, 2020 at 7:21 PM
    glowblue
    VA
    ^This. I saw some reports that Amazon synthetic oil is actually API certified and pretty good stuff for the money.
    MS22 and Rica25 like this.
  16. Jan 14, 2020 at 7:25 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Interesting. Is there a link or anything to that testing by chance?
    Rica25 likes this.
  17. Jan 14, 2020 at 7:32 PM
    14 Tundra
    2014 White Tundra
    Leveling lift kit
    Thanks everyone for the feedback. I'm going to try the Mobil 1
    Appreciate it!
    Ajkkane, classiccat and Rica25 like this.
  18. Jan 14, 2020 at 8:21 PM
    RDRunner
    RDRunner New Member
    It is just their claim or sales pitch.
    My truck has used some oil at times (and it has less than 50k miles) and I did some reading and found out that the 5.7 Tundra engine has a problem with rings sticking from the oil cooking on the top piston ring (I forget the exact terminology). This is a common problem with a lot of newer engines because of the piston design to obtain better emissions, etc. Anyway, I was using Mobil 1 when the truck was using some oil so I switched to Pennzoil. It seemed to help but I am not certain (too soon too tell for sure). I am not a fan boy of any product (well maybe Toyota) so I could change my mind in the future about this oil. I also only use Shell and Chevron gas for the cleaning as well. I am pretty sure the oil consumption is due to the ring problem.
    BTBAKER[QUOTED] and Rica25 like this.
  19. Jan 14, 2020 at 8:25 PM
    mofferman
    mofferman New Member
    Windsor, CO
    2019 double cab
    always have used Mobile 1
  20. Jan 14, 2020 at 8:44 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Using Mobil 1 Extended Performance 0W20 for 10,000 miles. I loaded up on 20 quarts of Rotella/Shell Syn 0W20 last month, so that’ll be my go to for the next 30,000 miles.
  21. Jan 14, 2020 at 8:45 PM
    Rica25
    Ricardo
    Tulare
    150k and going strong have always used mobil1 and a few times only used valvoline have always used shell or chevron the only thing i might switch or test out is the 5w 20 instead of 0w 20
    georgiey22 likes this.
  22. Jan 14, 2020 at 8:46 PM
    georgiey22
    You have a sweet truck!
    Rica25[QUOTED] likes this.
  23. Jan 14, 2020 at 8:48 PM
    Rica25
    Ricardo
    Tulare
    :thumbsup:
  24. Jan 15, 2020 at 2:39 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Good stuff, they guarantee it too.
    Rica25 likes this.
  25. Jan 15, 2020 at 4:20 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Any good synthetic oil should be fine. I use either Mobil 1 or Valvoline Synthetic.
    Rica25 likes this.
  26. Jan 15, 2020 at 4:25 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Pennzoil Platinum is a good price and an outstanding oil. Quaker State Ultimate Durability is a sleeper oil that is fantastic and has the high moly that Toyota oil has as well as only costing roughly $19 a jug. Amsoil is an outstanding top tier oil but is too expensive, and Mobil 1 Extended Performance is right in the middle...fantastic top tier oil, but priced right.
    Take your pick.
  27. Jan 15, 2020 at 4:27 AM
    Stig
    Stig New Member
    Not this again. Anyone thats read the internet before knows this topic gets beat to death as everyone has their own expert opinion.
  28. Jan 15, 2020 at 5:26 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Go over to BITOG if you got nothing else to do at work. Or if you wanna stay up to date on what oils are on clearance/rebate.
    I'm sitting on 90 qts of free Shell Rotella Gas Truck thanks to BITOG
    Rica25 likes this.
  29. Jan 15, 2020 at 5:33 AM
    vanoss101
    vanoss101 New Member
    2015 SR5 Tundra DC
    Please no one use this advise as far as mileage..... Should never go more the 10K miles between oil changes no matter what you use.
    Johnsonman and Rica25 like this.
  30. Jan 15, 2020 at 6:11 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    :popcorn:
