09 tundra engine noise ?
Discussion in '2nd Gen Tundras (2007-2013)' started by Leonides, Jul 17, 2019.
  1. Jul 17, 2019 at 6:52 PM
    Leonides
    Leonides [OP] New Member
    Leonides
    2009 Tundra
    Pure Maintenace
    Hello , tundra from Spring Tx!!!
    What do you guys think about this noise in the engine area ..
    Sounds like it’s a knocking sound . You can hear it during idle and acceleration.
    https://youtu.be/tw6DUAUPRcY
    09 tundra
    4.0
    V6
    138k Miles
  2. Jul 17, 2019 at 6:55 PM
    15whtrd
    15whtrd Mr. Blonde
    I would stop driving it. And check the timing chain tensioner. I’ve heard of a few of those going bad.
    ColoradoTJ likes this.
  3. Jul 17, 2019 at 6:56 PM
    15whtrd
    15whtrd Mr. Blonde
    That is a strange noise. Maybe even a bearing on one of the pulleys going bad?
  4. Jul 17, 2019 at 7:05 PM
    Pull the serpentine belt and restart (when cold) for 10 seconds. If the noise is still there, I would say timing belt tensioner as well. How many miles?
    15whtrd likes this.
  5. Jul 18, 2019 at 2:42 PM
    Leonides
    Leonides
    2009 Tundra
    Pure Maintenace
    Ok , thanks for the info guys !!
    Just got word back from mechanic shop
    Shop is saying it’s going to require rod work . Has bad / worn rod and possible replacing engine .
    Repair ranging from 4K-5k
    Depending on used or new engine .
  6. Jul 20, 2019 at 3:29 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    Get a used oil analysis before you do anything.
  7. Jul 20, 2019 at 2:20 PM
    Leonides
    Leonides
    2009 Tundra
    Pure Maintenace
    Thanks for heads up Sgt.
    taking in Monday for second opinion .
    Been fighting The temptation of servicing before we find more info...
    Wish me luck !
  8. Aug 5, 2019 at 9:15 PM
    Leonides
    Leonides
    2009 Tundra
    Pure Maintenace
    Repair Update :
    Got a second opinion and it was as belt tensioners and exterior engine components ..
    Thank god for second opinion .
    The 2nd mechanic did pull belt off and verified no noise without belt ..
    And not internal engine problem ..
    bvia, 15whtrd, SgtNewundies and 2 others like this.
  9. Aug 6, 2019 at 4:00 AM
    SgtNewundies
    Eric
    Thankfully you are patient. There are lots of scammers out there and incompetent people.
    15whtrd likes this.
