08 Tundra wont run once warmed up. Any ideas?
Discussion in '2nd Gen Tundras (2007-2013)' started by Thinnius, Jun 14, 2018.
  1. Jun 14, 2018 at 11:32 AM
    Thinnius
    Thinnius [OP] New Member
    Pinon Hills, Ca
    08 TRD Tundra 5.7 - 4x4
    Hello all
    I had my tundra die on me while driving one night. Couldn't get it started back up. I had it towed back to the house. I had trouble with battery earlier in the week, but was able to charge it. So I replaced the battery thinking that might be the issue, but it didn't help. Still wouldn't start. I added some gas to the tank even though the gauge was reading 1/4 full. Was able to get it started. but it died again once it warmed up. I replaced the fuel pump. Same problem. I also replaced the spark plugs to no avail. I did find oil in 3 of the spark plug tubes on the left side. Not sure if it's related or not as I've heard that's a common problem. Hoping someone might have some ideas. Any help would be appreciated. Thanks.
  2. Jun 14, 2018 at 11:41 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Clean the throttle body and mass air flow sensor. I had a 4Runner I replaced the battery on and it wouldn't stay running afterwards. Cleaned MAF and TB, let it relearn the idle, runs like a champ.
    Sunnier and Thinnius[OP] like this.
  3. Jun 14, 2018 at 11:44 AM
    blizz86
    blizz86 New Member
    How much oil were in the spark plug cylinders? Whats your battery voltage at once it warms up?
    Thinnius[OP] likes this.
  4. Jun 14, 2018 at 11:45 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Alternator are the culprits!!!! See forum on this issue. Especially if you up in the 150+K miles
    Faulty plugs would give a rough idle before shutting down
  5. Jun 14, 2018 at 12:09 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    Yes, alternator could be the issues. Slipped my mind.
  6. Jun 14, 2018 at 12:48 PM
    Thinnius
    Pinon Hills, Ca
    I will check the MAF and throttle body.
    The battery sits at about 12.5 when warm.
    I think I checked the alternator a few weeks back but I will check again to make sure.
    Not sure how long it should take for the computer to relearn the idle.
  7. Jun 14, 2018 at 12:50 PM
    Thinnius
    Pinon Hills, Ca
    There was a bit of oil on one plug and much less on the ones on either side.
  8. Jun 14, 2018 at 12:57 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    sediment in the gas tank?
  9. Jun 14, 2018 at 1:55 PM
    Thinnius
    Pinon Hills, Ca
    Nope. No sediment. It was clean.
    I actually just got it going. After replacing the fuel pump, I hadn't let it idle for long enough. I let it go for about 10 minutes and it upped the idle. Running like a champ now.
    Thanks for your help guys. Super excited.
    Sunnier, Y0TA PR0 and mudslinger79 like this.
  10. Jun 14, 2018 at 5:16 PM
    el_taco
    el_taco New Member
    Alt should be about 14.2ish (or close to it) when running, 12.2-4 when not running. If your engine is running and you are at 12.5v and you said youve replaced the bettery...most likely yer alt.
    Thinnius[OP] and Sunnier like this.
  11. Jul 1, 2018 at 4:31 PM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    Do you have codes stored in the ECM?
