08 Tundra Weird Indicator Issue
Discussion in '2nd Gen Tundras (2007-2013)' started by JeffraKing, Nov 3, 2020.
  1. Nov 3, 2020 at 8:20 AM
    JeffraKing
    JeffraKing [OP] New Member
    Jeff
    2008 Tundra SR5 TRD Offroad - 5.7L
    None that I know of
    Hi All,
    Not sure how to describe this other than weird. Here is what happened.
    Started down the road this morning and a flashing L4 light came. Nothing seems out of the ordinary but I wanted to check it out anyway. Pulled into a parking lot and shut it off to check the manual (not much in there on that light other than that it is the Low 4x4 light). When I started the truck, all lights went out as normal. Started driving and a whole bunch of lights came on: Check Engine, L4 (flashing), VSC Off (Flashing) and Traction Control. Truck was functioning as normal so I drive it 20 miles to home without incident.
    Before shutting it off, I grabbed my code reader and noted that it threw a P0705 code (Transmission range sensor). I cleared the error and the Check Engine + the L4 lights went out. Shut it off and restarted, all lights are now out. Drove it a few miles - no lights.
    What the heck just happened there?
    One note - since it has been getting cold, the shift from Park to Drive is a little stiffer than normal.
  2. Nov 3, 2020 at 10:40 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check for damage on the wiring.. You may need a mirror or an endoscope to look on top of the transmission.. unless you drop the transmission or dwarf to a G.I. Joe 6 in. figure to fit up there, don't think there is any easier way...
  3. Nov 3, 2020 at 10:47 AM
    JeffraKing
    Jeff
    None that I know of
    Yeah - I think I have a little mirror somewhere. I will check it out. Those logging roads in Maine a few months back may have taken their toll on the wiring. Still clearing out mud.
    Seems fine now - no lights. The stiffness of the shiftier concerns me some. It's the T handle option (no button on it) that was put on long before I bought it. It's a Toyota option. It might just have been stuck in a spot that did not trip the sensor properly.
    I saw a thread on here with somebody having a very similar issue (same symptoms) and it was actually a fuse. I will check that out too.
  4. Nov 3, 2020 at 10:56 AM
    JeffraKing
    Jeff
    None that I know of
    blackdemon_tt likes this.
  5. Nov 3, 2020 at 9:26 PM
    blackdemon_tt
    Seems like you sorta gotten an answer..
