08 tundra shifter stuck and more
Discussion in '2nd Gen Tundras (2007-2013)' started by db385, Jul 27, 2020.
  1. Jul 27, 2020 at 1:34 PM
    db385
    db385 [OP] New Member
    dave
    08 tundra 5.7
    wheels/tires
    O8 tundra 5.7 shifter stuck, Brake light on, abs light on, and TPMS on. No ac,speedo, windows, radio, or wipers. Changed brake switch, alternator, ALL fuses, Battery new, good grounds. I'M Lost. saw some threads on forums but no solutions. HELP!
  2. Jul 27, 2020 at 11:05 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Maybe try a negative battery cable disconnect to reboot the system. See if that will clear things up. What was the last work performed on your rig before all the light came on? Rats chewing on wires?
  3. Jul 28, 2020 at 6:55 AM
    db385
    dave
    08 tundra 5.7
    wheels/tires
    Brought truck to mechanic was rebooted a few times and all wires/ grounds looked good. Getting under it today. Also, when lights come on alternator puts out 12.3 volts. This entire problem is an intermittent issue it does not happen all of the time
  4. Jul 28, 2020 at 6:58 AM
    db385
    dave
    08 tundra 5.7
    wheels/tires
    Brought truck to mechanic, all wiring/ grounds looked good. Rebooted ecm. This entire issue is intermittent. It’s a bear to find the problem. Also when issue occurs alternator puts out 12.3 volts
  5. Jul 28, 2020 at 8:21 AM
    FWD Tundra
    Washington
    Sounds like you need to concentrate on the charging system. 12.3 volts is not enough to keep battery charged and triggers the warning lights. On all the Toyota’s I have ever worked on, when there is problems with the charging system you will get 2 lights 1) the brake light and 2) the charge light. With those 2 lights on indicates to me the charging system is faulty. That needs to be ironed out first.
    Would not be the first time I have seen a bad alternator bad from store, especially the lifetime rebuilds. If you did purchase a rebuild I would return it and buy a new one, not a rebuild or overhauled.
    Are you sure your Alt belt is not slipping on the Alt pulley when under heavy current load?
  6. Jul 28, 2020 at 8:41 AM
    Threads merged.
  7. Jul 28, 2020 at 11:25 AM
    db385
    dave
    08 tundra 5.7
    wheels/tires
    Old alternator did same think. It’s why I changed it out. Once truck runs a while it will click, then everything works fine. Battery is good
  8. Jul 28, 2020 at 6:00 PM
    FWD Tundra
    Washington
    What goes click? You need to narrow down your source of the click. I don't have any wiring diagrams for the Tundra, but it sounds like a relay if it is going click. Maybe a load relay?
  9. Jul 29, 2020 at 10:03 AM
    db385
    dave
    08 tundra 5.7
    wheels/tires
    checked relays in fuse panel under the hood. all good. thinking ECM
  10. Jul 29, 2020 at 3:33 PM
    FWD Tundra
    Washington
    The ECM’s are generally pretty hardy but it may be bad. Sounds like junkyard time. At least try a used one first as I am sure an OEM would be pricy.
  11. Aug 5, 2020 at 8:37 PM
    db385
    dave
    08 tundra 5.7
    wheels/tires
    it was the fuse box connection under dash shorting out
  12. Mar 20, 2021 at 11:00 PM
    RockyMTNdaddy45
    RockyMTNdaddy45 New Member
    Jeremiah
    2007 Tundra Limited TRD Crewmax
    Grille Guard, LED light bar, backup camera, TRD cold air intake, Cat back dual performance exhaust, LED headlights, LED fog lights
    Do you know exactly what and where it was shorting out? I'm having the same problem and I'm banging my head looking for the problem.
