08 tundra rear axle bearing clip/washer ?
Discussion in 'General Tundra Discussion' started by Dcampbellava1, Feb 10, 2019.
  1. Feb 10, 2019 at 1:43 PM
    Dcampbellava1
    Dcampbellava1 [OP] New Member
    David
    2008 tundra 5.7. 2wd off road TRD SR5 crew cab r
    None
    Hey guys. I am having my rear axle bearing replaced on the 08 Tundra. My usual mechanic whom could not find a press large enough to do the job) told me that there is a clip that is not included in the bearing kit he said I would probably have to order it separately from the dealership. I read on another Forum that there is a washer that is not included. Are they referring to the same part? I just want to make sure that the mechanic who is doing the repairs has all the necessary info so as not do the job wrong. Thanx
  2. Feb 10, 2019 at 3:00 PM
    koditten
    Kirk
    Midland of the Mitten
    He is wrong. The berrings get pressed on as an assembly.
    The only thing holding the axles in are the 4 bolts thru the axle flange.
    15whtrd likes this.
  3. Feb 10, 2019 at 3:30 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe it’s shims he’s talking about? Do shims have to be placed under the bearing to get the right preload?
  4. Feb 10, 2019 at 4:35 PM
    koditten
    Kirk
    No shims. The berring housing is bolted to the axle flange.
    15whtrd likes this.
  5. Feb 10, 2019 at 4:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Ok I was thinking the pinion bearing.
  6. Feb 10, 2019 at 5:21 PM
    koditten
    Kirk
    True, but you don't have to do anything with the punkin doing axle berrings.
    If you think you need a pinion berring, then shims may be needed to adjust back lash.
    15whtrd likes this.
