08 tundra 4wd issue
Discussion in '2nd Gen Tundras (2007-2013)' started by JDM1990, Jul 9, 2025.
  1. Jul 9, 2025 at 11:12 AM
    JDM1990
    JDM1990 [OP] New Member
    08 tundra sr5
    When 4wd switch is turned from 2wd to 4hi it initiated the transfer case actuator, 4hi light on dash blocks 8 times slow, no movement on add actuator, then disengages transfer case actuator and starts blinking fast. Any suggestions?
  2. Jul 9, 2025 at 11:12 AM
    JDM1990
    Add actuator moves when hooked to battery also
  3. Jul 9, 2025 at 4:54 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    The transfer case has to shift and engage first and then the ADD shifts. If the transfer case isn’t shifting completely the ADD will not actuate. So, could be wiring of the actuator. The transfer case actuators have been know to give trouble.
    Did it work correctly at some point and now it doesn’t?
  4. Jul 9, 2025 at 5:28 PM
    JDM1990
    Yes it worked at a while ago. The front driveshaft locks in whole the light is flashing slow, thinking it might be the 4wd position switch. Could someone tell me the pin correspondence on the actuator side?
  5. Jul 10, 2025 at 8:27 AM
    huntertn
    huntertn New Member
    Tennessee
    Tundra2n3 likes this.
