08 sequoia 4x4
Discussion in 'New Member Introductions' started by mjbjw77, May 11, 2025 at 10:07 PM.
  1. May 11, 2025 at 10:07 PM
    mjbjw77
    mjbjw77 [OP] New Member
    Yesterday
    08 sequoia
    Good evening,
    Looking at an 08 sequoia with its hi/lo actuator fault.
    What is the consensus if I would undertake this?
  2. May 12, 2025 at 4:25 AM
    Likely replacing the corroded actuator. A chance you could remove, clean up and re-use the original, but they normally won’t be salvageable due to extensive corrosion from neglect.
  3. May 12, 2025 at 4:35 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. May 12, 2025 at 7:05 AM
    Welcome from NY.
