'08 - Replaced starter July '21, need to again.
Discussion in '2nd Gen Tundras (2007-2013)' started by Scree-Doze, Mar 26, 2022.
  1. Mar 26, 2022 at 2:31 PM
    Scree-Doze
    Scree-Doze [OP] New Member
    2007 Crewmax Limited
    My 5.7 '08 4x4 had a dead starter last July. Local mechanic did the fix (said it was likely one of the worst jobs he's done, he had never seen a starter that difficult to remove). Charged me $550, which reading on here seems to be way below what many others are paying.
    The ugly part...it happened again. I attempt to start, dash lights all come on, and I just get a single loud *click*. Then nothing. Same as back in July. Tapping the starter doesn't work. Fuses look good. Attempted to jump from another car, as well as with a portable jump kit. With the portable jump kit, battery shows 14.6. No turn over, to try, just that single loud *click* then nothing.
    I'm not really certain I'm asking for help, as I'm pretty certain its the starter. But if anyone has some idea before I call and look at round 2 starter replacement, I'll give it a shot.
  2. Mar 26, 2022 at 2:39 PM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Call who everyone installed it and ask him about it. Should be under warranty.
    AlexJD likes this.
  3. Mar 26, 2022 at 7:47 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    Most places are at least 12 month warranty.
    When mine went out I bought a new one at the dealership because I have had too many problems with aftermarket crap from auto parts stores. I was not gonna take a chance on something that hard to swap out.
  4. Mar 27, 2022 at 4:28 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    As much labor involved with the swap using an aftermarket starter is asking for trouble.
  5. Mar 27, 2022 at 6:39 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Check for loose wiring. It’ll be a bitch to check the starter side but doable. Make sure you’re ground connections are tight as well.
  6. Mar 27, 2022 at 8:55 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Sounds like you are on the right track. Seems cheap aftermarket starters from the chain auto parts stores are really just remanufactured junk.
    If you end up having it replaced again, I would recommend shelling out the $$ for a real high quality new one. Dont cheap out on one its not worth it.
    myt1 likes this.
