08 Low beam HL , Relay power from ?
Discussion in '2nd Gen Tundras (2007-2013)' started by wilktres, Feb 14, 2024.
  1. Feb 14, 2024 at 6:51 PM
    wilktres
    wilktres [OP] New Member
    My hi beams work, low beams don't. I'm retired electrician and yes all relays ok, fuses checked. In the large fuse block under the hood are hi and low HL relays. I have found the +12v pin (which is hot) for the hi relay in the relay socket base. However the corresponding pin in the socket base for the low relay is dead. It is a small job to turn over the fuse block to see what feeds that pin, I have 4 mounting screws out with no avail. Is someone knowledgeable or have schematic? Thanks for any help.
