08 leaking engine coolant?
Discussion in '2nd Gen Tundras (2007-2013)' started by barretwe, Nov 27, 2016.
  1. Nov 27, 2016 at 2:51 PM
    barretwe
    barretwe [OP] New Member
    2008 tundra 4wd trd
    I have had my 2008 tundra in the shop getting the AC repaired. And the mechanic was having trouble fixing the problem then finally realized it was the compressor. He replaced the compressor and the drier. The AC seems to be blowing cold but now I've noticed (after getting my truck back yesterday) that now I'm leaking a good amount of coolant. The leak is coming from somewhere above the drain pan and I can't seem to find where it's leaking out of. I don't have any cracks in the overflow reservoir and the hoses seem to be good. Does anybody know what could be going on? Is it possible that they had to disconnect or remove the radiator or parts to it to replace the compressor and did not reconnect all parts? Any help is appreciated.
  2. Nov 27, 2016 at 3:14 PM
    Welcome to the forum.
    First thing you need to do is drop the skid plate, chock the tires/parking brake, make sure your fluid levels are good, start the truck, get under the truck and see the leak.
    Most likely, the radiator was removed. The clamps to the radiator hose/radiator may not have seated properly and is leaking by when the system comes up to pressure.
    I would also be calling the shop back.
  3. Nov 27, 2016 at 6:01 PM
    barretwe
    2008 tundra 4wd trd
    Thank you. The best I can tell it's coming out of multiple places. Not looking good.
  4. Nov 27, 2016 at 6:05 PM
    Water pump? Gasket going out?
  5. Nov 27, 2016 at 6:06 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    I'm with TJ on this. Also, our Tundras are kinda known for cracking the radiator. Regardless, it's a solid place to start.
    But i'd definitely be on that shops ass. And if the radiator cracked it's most likely due to improper reinstallation which is the shops fault.
  6. Nov 27, 2016 at 6:14 PM
    Wonder if the shop attempted to pull the compressor out and punched a few holes in the radiator?
    FlashCulprit likes this.
  7. Nov 27, 2016 at 6:22 PM
    Wonder if he's taking to that shop before or check its rating
  8. Nov 27, 2016 at 6:23 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    Definitely my thought. I've done a few radiator replacements the Tundra and if a tech is sloppy they can crack pretty damn easily.
    Unfortunately, our radiators have cheap plastic on the top and bottom. Hairline cracks happen due to pressure issues, weather changes, and improper coolant levels (overheating), not to mention it becomes brittle throughout the years. Also, check to see if your coolant cap is bulging or concaved - this could indicate previous stress on the radiator which could have caused it to crack under pressure.
  9. Nov 27, 2016 at 6:28 PM
    Huh, learn something new every day. I was not aware of the radiator issues in the Tundras.
    :thumbsup:
  10. Nov 27, 2016 at 6:28 PM
    Neither was I.
  11. Nov 27, 2016 at 6:35 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    I wouldn't say it's much of an "issue" but over the years more and more manufacturers have turned to using plastic making them more prone to failure. haha Regardless, it's not a terrible replacement. And replacement parts are found for pretty low prices. Just keep your fluids in check and you'll be peachy.
  12. Nov 27, 2016 at 6:37 PM
    Bigmoo
    Bigmoo New Member
    07 Tundra SR5 TRD
    73afb7750fb985e29b36376778c90dee_ff8787cca0ff84ab9d6359f49a70a649f2b4c4a7.jpg1c7e63541803d9248dc1a0e75b4f32fd_1c0ac70e0d9b11ca7588ed6b4f956fb4151258cc.jpg
    Water pump on my 07 27k on it
  13. Nov 27, 2016 at 6:40 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    That's just unfortunate! You shouldn't have to deal with that until you are due for a timing belt.
  14. Nov 27, 2016 at 6:51 PM
    Bigmoo
    Bigmoo New Member
    07 Tundra SR5 TRD
    That was 2014 so it already 7 years old (bought it with 17k in 2013), it was quite the repair job,took me about 4 hours. PS no timing belt in the 5.7 to ever change
  15. Nov 27, 2016 at 6:59 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    True... Poor 4.7's. Gotta love dual chains.
  16. Nov 27, 2016 at 7:33 PM
    Mike Tread lightly.
    south carolina
    Smh.. they still go slack and still can break ask Nissan and there problems....
    ask any 22r/20r engine what the problem with chain was tick tick tick and the god damn guides going out... Fun I own a 22r.. tick tick tick.
    GNTundra likes this.
  17. Feb 27, 2018 at 3:29 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    My (pink) coolant is low after doing a engine check (2008 5.7).
    No signs of leaking.
    Can I use regular auto store coolant?
    GM Dexcool is also pink...... can I use that also?
    Pentofrost Antifreeze/Engine Coolant????
    What's the verdict?
  18. Feb 27, 2018 at 3:53 PM
    Do not use Dexcool. Personally, I just use Toyota Radiator fluid. It’s cheap.
    Radiator fluid will evaporate. I usually have to top off the Lexus and Tacoma from time to time.
    Les7311[QUOTED] likes this.
  19. Feb 27, 2018 at 3:55 PM
    Stay with OEM ...DO NOT MIX
    ColoradoTJ and Les7311 like this.
  20. Feb 27, 2018 at 3:55 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    i keep with toyota brand coolant... ebay's been the cheapest place i've seen it. A buddy of mine who's super nerdy looked in to the chemical side of things and low and behold, Toyota coolant is slightly different. I didn't bother double checking, just took his word for it and bought red stuff.
  21. Feb 27, 2018 at 4:08 PM
    Les7311
    Thanks all.
    I was about to go buy the pentofrost from advance Auto. ..... will spend the extra “mulah “ from the stealership
  22. Feb 27, 2018 at 4:10 PM
    Smart man. Your very expensive cooling system and wallet will thank you later on down the road.
  23. Feb 27, 2018 at 4:54 PM
    Les7311
  24. Feb 27, 2018 at 5:54 PM
    Lol. Exactly.
    Weird, my wife does the same thing. Coincidence? I think not.
